What to look for when buying a 14bff?
Discussion in 'The Garage' started by sebban, Nov 8, 2005.
  1. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    I´m looking to buy a 14bff. and I think that it has a limited slip inside.
    Does it matter what´s inside if I want to have a Detroit locker inside??
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes, you will need an open carrier if you plan on installing a detroit into a 14BFF axle.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Anything you ever wanted to know about 14FF carriers is right here.
    Ira
  4. sebban
    Jan 18, 2005
    63
    sweden
    Sorry, I´m not a registered member so I couldn´t read it. :blush:
    When you install a detriot you replace the internals of the diff, are you guys sure that it wont fit? (C´mon I really want this to work..) ;)
    I´ve tried to find information about this on the detroit website but nothing..
    Thanks,
    Sebastian
  5. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    the spider section in a open and detroit is 4 pin cross. the factory gov lock / limited slip is 3 pin cross. wont fit. my thread linked on hear before has great pics of all the stuff you need to know about the carriers.
  6. sandawgk5
    Oct 28, 2003
    6,881
    Here is a pic of a detroit for a 14FF you can see the 4 pins SweetK30 is talking about. It is really simple to install. Open the carrier remove all gears and shims, install detroit, bolt up carrier.
    Ira
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    That is true to an extent. You replace the internals of the carrier. The detroit locker has the 4 pin cross of the open style 14BFF carrier. Since the gov-loc 14BFF's use a 3 pin "Y", the detroit will not work in the gov-loc unit. Search around, I'll bet you can find a used open carrier pretty cheap.
  8. sebban
    Jan 18, 2005
    63
    sweden
    What about shimming the gears?
    This guy also has a 14bff with an open carrier but it has 3,71 gears and not the 4,10 gearing that I need. I cant just swap the two carriers without shimming the gears can I? If not, is it possible to weld the LS version?
    I do 50% wheeling on the streets, will I break it when running on asphalt?
    Thanks,
    Seb.
  9. sandawgk5
    Oct 28, 2003
    6,881
    The 14FF does not use shims. The carrier is located by threaded inserts that press against the bearings. They are also used to set the bearing pre-load on the carrier bearings. The pinion bearing pre-load is set by using a Crushsleave between the 2 pinion bearings in the pinion retainer. You can take any carrier from any 14FF and move it to another one all you have to do is adjust the threaded collars to set your carrier pre-load and backlash. The only shims in a 14FF are for setting pinion depth but they are simple to install since the pinion is housed in its own carrier that easily unbolts from the center section. The shims go between the center section and the pinoin carrier. If I have thouroughly confused you let me know and I will try to find some pics.
    Ira
  10. sandawgk5
    Oct 28, 2003
    6,881
    Here is just about everything you ever wanted to know about the 14FF. At the top of the page there is the military 14FF service manual.
    Billavista's 14 bolt bible
    Ira
  11. sebban
    Jan 18, 2005
    63
    sweden
    thanks guys!
    I´ll buy the open carrier with 3.73 (or 3.71 or whatever it is.. :doah: ) ;) Then I´ll install the 4.10 gears that I want plus the detroit.
    :D :D
  12. sandawgk5
    Oct 28, 2003
    6,881
    That is what I am in the process of doing right now. :D
    Ira
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Good luck setting up the used gears. Sometimes it goes easy, sometimes you'll give up infrustration. Ask me how I know :( :doah: I'll never set up another set of used gears..EVER! :haha:
  14. sebban
    Jan 18, 2005
    63
    sweden
    Well I´m gettin a new set so hopefully it will be a bit easier.. :wink1: :wink1:
