What to paint headers with
Discussion in 'The Garage' started by 87BrnRsd, Aug 24, 2004.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I am going to be purchasing a set of headers soon that wont come from the factory with a ceramic coating. What kind of paint is good to coat them with that will keep them rust free for the longest possible amount of time? My brother used that hi-temp ceramic paint from autozone on his, but it burnt off rather quickly. /forums/images/graemlins/dunno.gif What works? Thanks.
    -Harrison
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nothing works, that's why people pay twice as much for ceramic coated headers.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive had good luck with the black paint thats rated to 1500*. it lasted a few months. nothing is perminent not even ceramic coating.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Yepp, high temp BBQ/Stove paint...seems to work ok on mine, but there is some nice hardened clay on there that I know is gonna take paint off /forums/images/graemlins/grin.gif
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I found that out. Paid a few hundred for my ceramic coated headers and lasted about a year or so and now there are stained with red clay and some fire extinguisher stuff.
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Have you thought about just using some of that heat wrap instead? It will probably always look the same, and you get less heat under the hood, which is good for everything. /forums/images/graemlins/dunno.gif
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one of my friends put that wrap onhis and they cracked bad, don't know if the wrap caused the crack or what, but he hasn't put any one it since and has not had a problem, soo /forums/images/graemlins/dunno.gif
    BTW same truck, same exhaust, same brand headers /forums/images/graemlins/dunno.gif
  8. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    Try POR 20, I've always been happy with their stuff
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    The dupli-color 1500* stuff works as good as VHT for me. Either way, you have to repaint them every so often. The lower parts seem to rust quicker for me, but they are easy to scratch up and hit with the rattle can without removing them.
    I like the idea of the lifetime warranty ones from Autozone, though. Just spend $5 on a can of paint once a year when you replace them.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I used Krylon BBQ paint good for 1200*. Most of the paint baked off the next day... Try something with a temp range over 1500* if there is such a thing.
  11. 87BrnRsd
    Apr 21, 2003
    2,457
    Thanks to everyone for their suggestions. I am going to look into the por-20, and also the krylon 1500 degree paint. If I happen to find a coating with an even higher rating than 1500 degrees, I will post it up to let evryone know about it. Thanks.
    -Harrison
  12. 1972jimmy
    1972jimmy Registered Member
    Nov 7, 2003
    24
    Denver
    The trick, even with the 1500 degree paint, is to bake them in an oven before putting them on (follow the directions on the can). This doesn't make it permanent but makes a huge difference versus not baking.
    Probably a good idea to buy the wife a day spa on the day you plan to bake. Gotta have a good size oven too.
  13. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    You need to get the headers hot before you paint them to burn the factory paint of or sand them down to the metal then after that you can paint with some high temparature paint. If you paint over the factory paint your paint will burn off when the factory paint burns off.
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Another thing to note is to use very thin coats and only do as many coats as needed for complete coverage. Laying it on thick doesn't last. If you can still sort of see raw metal under the first coat, that's about right.
    Liked the VHT orange a friend put on the BBC headers on his '60 El Camino. They turned bright red when they got hot enough to burn you.
  15. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I stipped a set down to bare metal and powder coated the red. Now the powder burnt right off in about 30 seconds on the tubes but it stayed on the flange. The weird thing is the tubes never rusted. They looked like clean bare metal. I sold the truck about a year later and they still looked clean. /forums/images/graemlins/dunno.gif maybe the powder coat left something behind.
    It was kinda funny and heartbraking at the same time to watch the powder coat curl up and fall off in big sheets. /forums/images/graemlins/doah.gif
