What to put in spring packs...teflon?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Dec 30, 2001.
  1. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    hey guys. I have my rear springs all apart right now anyway, and I was wondering what I should use between the leaves. My packs have the factory teflon thing between the bottom 2 leaves...but not much else.
    One of my local 4x4 buddies said I should put some UHMW (ultra high molecular weight or something) plastic in there. Supposedly better than teflon for this app. Any ideas? What do you guys use, and do you have a little sheet of this stuff between each leaf or just the bottom ones. Whatever u use, where do you get it?
    Help appreciated! As soon as I get the 1" zero rates from ORD (thanks for the speedy shipment SW!) on monday, the springs are going back on...want'em to be as good-to-go as possible. ;)
    Jason
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I bought the plastic buttons from a local spring shop that builds the springs for many US brands (including James Duff cant recall the huge list the guy spielled off)
    $0.30 each
    formerly 77chev
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Off-Road magazine did an article on this awhile back. I think either UHMW or Teflon would be good. They put a thin "sheet" between each leaf( the same dimensions as the leaf) if I remember correctly. Look in the yellow pages or the web for Plastic suppliers.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    &gt;the same dimensions as the leaf
    wait a sec...the *same* dimension as the leaf? ie, length-wise too? I thought all that was needed was a piece maybe 6" long, that would be centered on the spring packs center pin. If not, lemme know! Wanna get it right the 1st time. =)
    J
  5. Michael
    1,576
    Sherman, Texas
    OK, I found the article.....this is what they did....
    1) Deburr all the ruff edges on each leaf with a grider or file.
    2) Coat each spring with epoxy paint.
    3) Place a "liner" the full length and width between each leaf.
    It seems that most of the friction occurs at the ends of the leafs....that's why you find manufactures using the plastic "buttons" at the ends. A full length just seems like it would be even better....
    They never said which plastic to use, but it looked like they went with UHMW. They said between .030-.060 thick material. They got it from www.jmartin.net/parker/goose.htm
  6. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    michael...awesome!!! Thanks much man. that helps a lot! The other thing thats cool, is that I already did the de-rusting phase...and the only paint I had left to use on them just happened to be some epoxy-based stuff. =) Looks like I stumbled into doing the right thing once again! ;)
    Jason
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Jason, there are a couple of places in Portland that sell HMW in various forms, sheet/rod, etc. Check the yellow pages. I just can't remember the names but one is down by Portland State.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  8. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    whoa...I'll have to look into that, thanks man!!!
    J
  9. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    whats the benefit of the stuff anyway?
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Teflon isn't the right stuff to use for that application. Telfon cold flows, that is, it will actually spread itself out thinner and thinner when under pressure. I think you would pretty quickly be replacing it with something more durable.
  11. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    It lets the springs flex better and gives you a smoother ride.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  12. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    UHMV is the stuff to get...just don't grease it. The grease will attract all sorts of debris and the debris will get embedded in the UMHV.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  13. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    Any ideas on where to get it? Can it only be had at specialty plastic suppliers or...?
    J
  14. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I've used plenty of it through my work, but I've never had to buy it or source it...sorry.
    Rene
  15. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    So....you get it from work or something? Hook me up man! =p j/k,
    J
  16. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    Teflon's real good. I have had a lot of luck adding some Lithium-based White Lube during the assembly, and that keeps them quiet for about 1 year (or until winter's damage).
    I found some lithium white lube in a spray bottle, and I can jack up each wheel and spray in a bit of that, and they're good to go again.
    Also, every water crossing washes the lube clean, so it's spray time again.
    The stuff also works on sqeaking steering wheels, door hinges, and not-K5 related but sliding glass doors too.
    <font color=blue>I don't know everything, I just think I do.............</font color=blue>[​IMG]
  17. BurbinOR
    5,829
    Oregon
    By the way, using dry graphite lube is good, it won't attract dirt. Grease of any kind will.
  18. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Most of the UHMV stuff we get is round stock or thick slabs...but I'm sure any thickness would be available. I'll ask where they get it from when I return to work on the 2nd of Jan. [​IMG]
    Rene
  19. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I think you can get graphite to paint on them from a tractor supply store......
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I'm in shape.... round is a shape......
