What to torque a 3/8" grade 8 bolt to??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Oct 18, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    What to torque a 3/8\" grade 8 bolt to??
    The back rear spring perches on my truck were sheered off. I will be bolting them back on with grade 8 hardware. I can't find any torque specs in my shop manual since these were originally fastened with rivits. Is there a general rule of thumb for torque specs based on size and grade?
    Thanks,
    Eric M.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: What to torque a 3/8\" grade 8 bolt to??
    Do you mean the whole shackle where it connects to the frame sheared off??? /forums/images/graemlins/shocked.gif That takes some serious abuse to do that.
    As far as torque, a standard (grade 0-2) 3/8" bolt should be torqued to 30 ft. lbs. I wouldn't have a problem torqueing a grade 8 to around 60-75 ft lbs. Just put a lock washer on, torque the bolt to 60 ft lbs. and make sure the washer is smashed down. You should be fine.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    with grade 8 of that size you could easily go to 90-100lbs
    You could also enlarge the holes and go with bigger bolts. /forums/images/graemlins/thumb.gif
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Don't go above about 45 lb-ft with a 3/8 fastener. You want to preload it, not break it. Use hardened lock washers.
  5. sleeper_dave
    sleeper_dave Registered Member
    Oct 12, 2002
    17
    When i replaced the spring perches on mine, i used a 1/2" ratchet and torqued it as hard as i could. It hasn't come loose or broken any bolts yet, and i've taken it through some stuff since then.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Now that would be a lot, I used to do that before I got the torque wrench, now I found that most times I got 200lbs, that's why I use the torque wrench now.
    Head bolts are torqued around 180lbs and they still work the same way loaded not to the point of stretching. 90 isn't too much, but you could go with 45 wih a lock nut, that will keep the pressure on and make sure the bolt doesn't loosen up.
    You might also want to invest in a little loctite.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Here you go - Torque specs </font color>
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Dude, what head bolts are you torquing that are 180 ft. lbs. /forums/images/graemlins/shocked.gif Small block chevy's are 65 ft. lbs.
  9. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks Shaggy,
    That's what I was looking for.
    Eric
