what to torque differential cover bolts to
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jan 1, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i just replaced the gasket in my front differential on my 87 k5 and i was wondering what to torque the bolts to, thanks.
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I wouldn't go more than 25 or 30. I usually just snug mine enough to squeeze the rtv out.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I second that!! [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 1987 GM factory manual lists it as 20 ft/lbs for the 10 bolt axle. [​IMG]
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    But then again, I've never used the torque wrench on the cover bolts. [​IMG] I just give the RTV 20-30 minutes to skim over good, then put the cover in place and lightly snug up the bolts. I come back an hour or more later and tighten up the bolts firmly and fill 'er up with oil. This gives the RTV plenty of time to harden so it won't squeeze out when the bolts are tightened. [​IMG]
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    20 ft pounds
    I believe in torqing the diff cover bolts to factory specs. The cover is designed as a part of the axel. When properly torqued it provides added support and helps to keep the housing from distorting under heavy loads. A 10 bolt needs all the support it can get so it should be torqued to factory specs.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
