what to use after frnder triming
Discussion in 'The Garage' started by oatsk5, Mar 11, 2006.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    for moulding to help protect the tires from cuts i thought i had seen somthing on here but i cant find it and i did search but probly not wording right
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmm that is a good Q
    whatever is used it better be tough
    that tire rub would tear up something that wasnt metal, real quick i would think
    im not gonna worry about it on my 77, as im not gonna be out anywhere where the tires could touch the cut edges
    hmm
    good luck
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    your supossed to trim till the tires DONT rub the fenders
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Door edge molding. It comes in chrome and black, and is very pliable. I used it so I don't cut my hand on the sharp edge.
  5. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    thanx and the tires dont rub it would be more cosmetic ?
  6. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    hammer and dolly...put a little rounded edge on it.
    ..but, like someone said already, supposed to cut till it doesnt rub anymore
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,957
    249
    Released from Pueblo, told I belong in Southpark
    I welded to inner fender and then speed lined. Door moulding works.
    you might check www.awdirect.com It is a towing supply company they have stuff like that.
    Search this has definately been talked about before. Good luck
    Some people have also taken a thin piece of metal like 1/8" that is flat and maybe an inch wide and weld it to bottom edge around the wheel well. That give a nice flat area if the wheel hits and a uniform roundness to the cut outs
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I bent the stock chrome molding and screwed it back on afterwards . Te screws go in the side now on the cut edge .
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    custom trim...
    I've seen a few trucks with 3/8" brake line tubing or solid metal rod stock welded on to the sharp edges,after bending to match the fender contour..needed it to pass inspection here (no holes,or sharp metal allowed)..:crazy:
