what to use for flat bed dump piviot point
Discussion in 'The Garage' started by sweetk30, Apr 16, 2006.
  1. sweetk30
    Nov 1, 2004
    horseheads , ny 14845
    i am putting a flat bed on my cab chassie truck. what is the best thing for the piviot point on the cheep for money?
  2. diesel4me
    Jul 24, 2003
    Lots of ways...
    Many guys just use a peice of "C" channel with 1/2" plate "hinges" with
    1-1/4" pins...similar to the peice bolted to a truck for the snowplow to pin into,only facing upwards..
    I'm thinking of making my flatbed I mounted on a trailer frame made from a 2wd pickup chassis,a dump body, instead of being bolted solid..I was thinking of using two peices of pipe,one that slides inside the other, to make a "hinge",and mount the outboard ends of the "inner" pipe by welding and bolting it to the top lip of the frame rails,after cutting a notch out of the pipe so it would sit flat on the frame on each side..then weld the other pipe to the bed..
    There is a lot of ways to do this..I'm sure others will post photos of their dump bodies to help you out..I'd like to see some too!..:crazy:
