What To Use For Pivot On Tire Carrier?
Discussion in 'The Garage' started by az ranger, Dec 15, 2006.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I am starting my rear bumper build and wondered what others have used for the pivot point on a swing away tire carrier. I want it to be as HD as possible.
    And what about bearings on it what has worked for you guys tht built your own.
    pictures would be helpful too.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Another option..........
  3. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Rockstomper has a pivot hinge with the tapered bearings and sleeve, pretty much all you need for the pivot. Just assemble and install.
    I would not recommend a swing out carrier though if you even think you might go to a bigger tire then 35's. My carrier broke off with a 39.5 mounted to it. Loud bang and then the end really lightened up. Bad - it happened on a major roadway with morning commuter traffic, good - it did not hit anybody so no one was hurt.
    Check out Blazenoffroad for a fold down carrier. Jesse does quality work and i am about to order a rear carrier from him. :D Very similar to Dontoe's pic.
  4. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    Sry to hijack but does anyone have any other pictures of those flip down carriers? I really like that Idea and it looks simple enough to fab.
    Thanx
    COry
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I agree..... I like swing ones that swing straight up/down. Built one for Robzilla that has worked well w/ many rollovers/flops. Instead of swinging down, it swings up. Used urethane spring bushings.
    Marv
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if you do a swing out what about a spindle and hub off a front axle. thats pretty heavy duty. you could use a 6 lug hub and cut off the flange for the studs. really trick would be to weld a stub shaft inside and use a locking hub to keep everything from moving. then unlock the hub and swing the tire out.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Heavy Duty - look here for a how to.
  8. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    I used wheel bearings from a camaro made spindles out of pipe and a 1"inch bolt though the middle .Weld-in a 1"nut on the bumper ,box it in ...call'er good ! I'd show you what I mean but I can't figure out how to post my pictures here.
  9. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Most of the fab shops here and what is on my tire carrier is jus Trailer hub and bearing assembly.
    here is mine, bad angle, but might help
  10. az ranger
    May 9, 2004
    139
    Safford AZ
    Marv,
    Do you have more info on how this works,
    keep the ideas coming this is great
  11. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    Was it the Rockstomer spindle that broke, and if so, where did it break?
    I'm finishing up a tire carrier now and I'm using the rockstomper piece.
  12. cbbr
    Jul 17, 2004
    14,681
    Look over on PBB. There are a few of them (rockstomper's)that have broken. Seems like they have beefed up the design since those were made, but I wasn't willing to take a chance.
  13. greyhoundjc
    Jan 23, 2005
    127
    Georgia
    I did see that post on pirate, that's why I'm worried. Honestly, the rockstomper piece does look pretty beefy, but I wish I had come up with something similar to what you did. Your bumper looks pretty darn sweet! :bow:
  14. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    They shear right off where it starts to taper down, fatigure failure.
    When we pulled our carriers from production, We tested our prototype and that is exactly where it snapped off.
  15. greyhoundjc
    Jan 23, 2005
    127
    Georgia
    I'm pretty far into this project with the Rockstomper piece. Any ideas of how to make it work? I was thinking that maybe other people had let there swing arm flex too much while driving and that the flexing motion was what was eventualy causing the spindle to break. I have tried to remove as much free play in my design as possible.
  16. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    It was not the rockstomper spindle that broke. It was a 1000# trailer axle bearing that broke. It snapped where the grease hole went through the tapered portion. I used the rockstomper one to repair what had been damaged. I have not had a problem with it but I am extremely concerned every time I take it on the road. Although I did add some hold downs on the swinging side which it did not originally have. I can post some pics if you like.
  17. greyhoundjc
    Jan 23, 2005
    127
    Georgia
    Pics would be great! I'm just concerned now that no matter what I do for a pivot point that every time I'm on the road, I'll be afraid that the swing arm will break off and kill someone. I usually overbuild everything, but if I think that there is anyway it could be dangerous I'll just have to scrap the whole project.
  18. 81jimmyslt
    Jun 5, 2003
    1,643
    It needs to have a second point of contact to fix that problem, or a better tire carrier spindle. You might be able to gusset the top like the picture above. Or hard mount a second pivot, maybe a simple bushing mounted to the corner of the body, just a thought.
  19. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If the first pivot is on the bumper you don't want the second to be on the body as it will work the sheetmetal until it cracks.
    Do really want three points of contact though. Two points make a line, which is an axis of vibration. Three points makes a plane, and the further apart those points are from each other makes it more stable.
    I'm confused, has a spindle from Rockstomper broken, or was it from some other source? I see one posting was some other source, but is that all of them? Scott E @ Rockstomper will want to know about such a failure if he hasn't already been told of it.
  20. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Please keep in mind that mine was "designed" for a 35" tire. It rode that way for quite a while with no problemw that I know of. Later the size was increased to a 39.5" x 15" meaning much heavier. (As a matter of fact, the right side of the truck is noticeably lower than the left. If you do build one place the tire in the center of the truck.) It rode like this for a while until the fatigue finally got to it. Also, there was not a second point of contact that was designed to clamp it down. It was just a metal rod intended to keep it from opening.
