What to use on leaky gas line threads?
Discussion in 'The Garage' started by Pookster, Jan 21, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    While installing my TBI spacer, I cant get the threads to stop leaking on the pressure side. Can I take it out and use thread tape? (the white stuff?). Is that gasoline safe? Or is there something else I should be using? Help!!
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The threads aren't what seal gasline fittings. They apply the pressure to the flare on the end of the tube. Take the line all the way out, there should be a "gasket" in there that probably fell out or is not in the right position.
  3. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    Actually, replacing the bad line and fittings is the best way to go...but I'm sure not the cheapest. Teflon tape is chemical resistant and should give you no problems...but the leak is probably due to poor fitting of the mating surfaces of the flared fuel line and the fitting on the adapter. Any nicks in either surface will cause a leak.
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im replacing the acorned nut part and cutting part of the tubing off and replacing it with flexible fuel line. 14-15psi will hold up just fine.
    However, the fuel line nut that goes into the injectors, i think it might be leaking from there, so I will use the teflon tape.
    In the mean time, Any suggestions would be greatly appreciated!
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've used teflon tape on fuel lines many times and never with a problem. /forums/images/graemlins/thumb.gif
    Rick
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    But why? As stated above, fuel line fittings are compression fittings. The threads don't act as a seal on a compression fitting, as they do an an NPT fitting. The problem with using teflon tape anywhere in the fuel system is that it shreds into tiny pieces when you take the fitting apart in the future. Those tiny bits can then find their way into tiny carb passages, injector screens, etc. causing a world of problems. /forums/images/graemlins/frown.gif Leave the teflon tape in the toolbox for home plumbing projects. /forums/images/graemlins/wink.gif
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    The problem is, I feel like something is still not right somewhere, and its leaking gas- I cant tighten it anymore, maybe I did loose an o-ring somewhere. I will pickup a new o-ring just to be safe.
    Keep the info comming.
    (thanks for the warning about the pieces of teflon tape. That could suck).
  8. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I'm not just talking about the fuel lines on the TBI. I work with fuel, fuel piping and lines for a living. We use it all the time on all of our fuel systems. I deal with gasoline, diesel and jet fuel. And I use it as a backup in case those little gaskets fail on my TBI. /forums/images/graemlins/thumb.gif
    Rick
  9. dyeager535
    26,980
    O-rings are usually in bad shape from my experience with TPI, which uses the same style of fittings. Even the o-rings on the injectors were torn up/hardened, and from what I could tell, they had never been replaced.
    Good luck finding the right o-rings for a decent price, standard ones aren't correct, they need to resist something like 200+* heat.
    I know where you can get them for about $2/each I think, if you have no luck finding them.
    As was mentioned, fuel lines are not made to use tape as the threads aren't made for it. You wouldn't use teflon on your brake lines would you? That said, I've done it before, if the fuel leaks around the tip of the flare, but not out through the fuel line/nut, it might come out of the threads, which tape will stop.
    FWIW, if it's not the "saginaw" style connectors (FI fuel lines, newer power steering line fittings) they are flare. Compression is what you use on natural gas lines and what not...typically a brass sleeve that is smashed into the copper (or aluminum) line by the fitting.
  10. 350350
    350350 1/2 ton status
    Sep 25, 2003
    939
    USA
    /forums/images/graemlins/1zhelp.gif Solder them like copper pipe fittings. /forums/images/graemlins/1zhelp.gif
    Paul 'X' /forums/images/graemlins/thinking.gif
