What to use on radiator crack?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Mar 22, 2003.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Today driving my gf's truck home, it overheated. Some stranger came along and saved the day. Had a bottle of coolant and some water. I limped it home and when I got there I started it up to find the leak, I found right away it was a crack about 1/2" long below the filler neck of the radiator. Does this need to be welded up somehow or is there a miracle potion that will fix the hole : Thanks
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    try jb weld or something similar. it's worked for me more than once.
  3. BowtieGuy3
    BowtieGuy3 Guest
    Well, other then buying a new radiator.....Your best bet is to get it brazed (you cant weld radiators due to their composition). If you have to/want to get a new one....I HIGHLY recommend this place for one, I use them all the time for my cars, and for racing:
    Speedway Motors
    I hope this helps...
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    All of the above recomendations are great, but try http://www.1800radiators.com they are really reasonable. I got a new 4 core fot my '87 for $164, including freight. The radiator wasn't a cheep Jap. brand either, it was a Modine radiator, which NAPA and the like stock. You can try using lead solder on the crack also, if you don't want to pony up for a new radiator. Good luck!
  5. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    take it to a radiator shop & have it fixed.
    whatever you do, don't pour pepper or that stop leak crap in it. That stuff tend to take a toll on your heater core.
  6. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    I fixed a similar crack on a radiator with a bottle of mapp (sp) gas and some solder. Just remember to clean the area to be fixed really well. The radiator shop will do the same thing. If it doesn't seal you can always still take it to the rad shop. Try it yourself it aint hard... /forums/images/graemlins/thumb.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Assuming it's a copper/brass radiator, any radiator shop can fix that in about 10 minutes. /forums/images/graemlins/cool.gif They'll clean the area, apply some acid flux, then solder it. You can do it yourself, but you have to be careful that you don't get the header tank too hot or the solder that holds the tank to the core can melt and then you'll have a new leak. /forums/images/graemlins/shocked.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    rad shop will boil and rod and solder the radiator for cheap
