WHat to use to insulate starter wire from headers/exhaust?
Discussion in 'The Lounge' started by TX Mudder, Jun 28, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I am talking about the wires that go directly to the starter - the start hot wire and the big red wire that carries juice to inside the cab.
    The go down the passenger side of the engine block, near the firewall.
    What can I do to insulate the wires from the exhaust component, esp. the manifolds. It would be even worse if I had headers. They are close to touching, and I really don't want to burn through the insulation and ground the positive battery cable.
    What can I do? If anyone has pics of what their's looks like, that would be cool.
    -- Mike
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Summit May have what you need...
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Get a F*ord starter soleniod and mount it on the fender. Heat Problem solved. I think summit sells the remote solenoid kit for about 25 bucks. And post this stuff in the 'Garage' forum it'll probably git more respones! /forums/images/icons/grin.gif
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I guess I didn't make myself clear.
    I am not worried about heat soak for the solenoid - I already have a heat shield. That is not what I am talking about at all.
    I am talking about the wires that go to the starter/solenoid. The run too close to the exhaust and I think they will eventually burn through and short.
    I need something to insulate the WIRES themselves.
    I would like to see a pic of someeone truck on the passenger side of the engine looking down. I would like to how the wires are routed and if they go through any conduit, etc.
    -- Mike
    -- Mike
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    On my old 73 Camaro, the wires ran through a metal tube. I'm sure you could get some wire insulatator. Call Jeg's 1 800 345 4545. I'm sure the sales adviser can hook you up with something. /forums/images/icons/wink.gif
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    I just zip tied them out of the way, I am running thorley tri-y's and when I first put them on I burned the wire to my coil, just reran it and the others and pulled them to safety with zip ties. Make sure to use heavy ones and to leave a little slack, haven't had a problem with them yet and they've been on for 6 months.
  7. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I used heat sleeves designed for plugs and strung a few of them together.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color="blue"> Summit May have what you need... .......
    I guess he didn't make himself clear either ..... Summit will have what you're looking for ! </font color>
  9. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I use an old heater hose that I slit and then tie-wrapped around the wires. Works excellent!!!
  10. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    mina also ran through a metal tube, all did at one time, you can make one, and slide the wires through it. available at any hardware store, use lightweight tubing /forums/images/icons/smile.gif and flexable!
