what to use to paint my rims?
Discussion in 'The Garage' started by muddybuddy, Mar 5, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im in the process of sanding down my rims to bare metal and am not sure what to use to paint the rims. i was thinking about using bedliner on the exterior of the rims and then putting a coat of spraypaint over them, and just spraypainting the inside (where the tire is). what would you guys use to paint your rims?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I did this to a set i had/have (don't use at the moment) i sanded them down to bare metal, sprayed a light coating of black primer to just cover the metal, and then sprayed them with semi-flat black.
    I like the look of semi-flat better, not so "flat" but also doesn't have that super high gloss of the glossy paint.
    Get ya a can and try it on something, see if ya like it, i'll bet you will :p:
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    i just scuffed mine with a "paint removing wheel" and then shot em with Rusteoleum or Krylon wheel paint, forget which...
    it doesnt hold up where the lug nuts seat, or if you scratch it with metal, but it is cake to touch up
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have found a place that does powder coating so im gona get a quote on that, if its rediculous, then i will likely go with rattle can i guess. if i dont like it i will just do something else
  5. 4xcrazy
    Oct 31, 2003
    9,472
    5
    that i guess is what i could almost compare the semi-flat black to, is this powder coating look....
    Honestly, i wouldn't spend the cash on powder coating, just paint them, it will turn out ok if you get everything clean and smooth.
  6. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    place down here in richmond named specialty finishes sandblasts and powdercoats wheels for 25 bucks a wheel...cant beat that...
