What to use to trim fenders?!?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ken, Dec 9, 2002.
  1. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    OK, I finally need to do it...trim the front fenders on two of my rigs. I have a Sawzall, but am thinking that will just hack the sh*t out of it and make it look like crap. What do/did you guys use??? An air nibbler?? Die grinder?> What??? HELP!!! Thanks!!! /forums/images/graemlins/thumb.gif
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    a sawzall will make a mess in my opinion.. use a angle grinder with a cutting wheel, a thin one...
    A sawzall will work but may give it a tearing affect.. i tried it on the back of the /forums/images/graemlins/k5.gif and switched to the grinder promptly! /forums/images/graemlins/usaflag.gif
  3. A plasma cutter /forums/images/graemlins/grin.gif
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    how about an air powered cut off tool /forums/images/graemlins/thumb.gif
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This is what I used. They make very clean cuts and is very easy to maneuver.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I tried all kinds of air powered tools from niblers to reciprocating to die grinders, nothing worked as good and as clean as the sawzall, but to each his own I guess.
    My first cut wasn't the greates but I didn't get close to the lines I wanted untill I had perfct control, then after the cut I snded the edges smooth and then rolled them for a factory look and a stroger edge.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I'll second the plasma cutter suggestion. Thats how I'm going to do mine. Just make a pattern/jig out of some kind of flexible material, Stick it onto the fender and use it as a guide for the plasma torch....15 seconds later, You're done- And no saw, or nibbler makes a smoother cut than a plasma cutter. /forums/images/graemlins/thumb.gif
  8. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    I tried both a cutoff wheel and a sawzall. the sawzall was by far the easiest. just get a friend to grab the fender as its getting cut so it doesnt vibrate. makes it much easier and cleaner.
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The plazma cutter is the ultimate in cutting hands down.
    It is next on my list, but I bought tools for more than 5k this year so it's going to have to wait for a couple of months.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Use a Saws-all.....I trimmed my fenders in about 15 minutes.
    I like Milwaukees Bi-Metal 24 teeth blades.....very clean cut. /forums/images/graemlins/cool.gif
  11. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Ken, I used a 4" grinder with thin cut off wheel, and it came out great...the Sawzall really rips it up, and when you get to the ends, there's just not enough room for it...the cut off wheel was quick and very smooth cuts...
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i used a cut off wheel, a sawzall and a grinder. cut mine all the way to the rear fender bolts. the second link in the sig links to what we did.
  13. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Thin Cut-off wheel and some clean filing gets my vote. Plasma torch?! I have one, but I doubt the investment of it for trimming fenders is a wise economical choice...but is nice to have in your arsenal /forums/images/graemlins/thumb.gif
  14. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    angle grinder worked well for me, i took a thin cut off wheel, then put a sanding disk on it, i was able to shave and contour the metal with the sanding disk..
    just have to watch the heat, i got it a little too hot and the paint around it started to turn black, so i cut a little more off and it was fine
  15. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    uh just lifted mine more no rubbig with 6 inch susp, 3 inch body 38.5 tsl's but then again it hasen't left my drive way...................sawzaw! /forums/images/graemlins/thumb.gif
  16. reddog64
    Nov 9, 2000
    3,325
    Just use a hack-saw blade and some vice-grips /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    I promise the power wont get away from you /forums/images/graemlins/smirk.gif /forums/images/graemlins/thumb.gif
