what tools to get "drive flange" style hub off?
Discussion in 'The Garage' started by y5mgisi, Mar 2, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    what tools to get \"drive flange\" style hub off?
    I need to get the hubs off a truck in the junk yard and have never had them apart befor.once you get the dust cap off, is it just heldin like other hubs(large snapring in the inside of hub pressing out) and a snap ring around the shaft and thats it? /forums/images/graemlins/ears.gif
  2. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    Re: what tools to get \"drive flange\" style hub off?
    Take dust cap off. Then take off EXTERNAL snap ring on end of the stub axle, and take bolts out of drive flange and remove flange. Then, it's jut the nut/locknut and the outer wheel bearing. Very simple.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    cool, /forums/images/graemlins/thumb.gif What kind of bolts are the ones that hold the flang in (allens?)
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Bolts? /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  5. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Yeah he said there was bolts in the drive flange(mabey he thought i ment rear or somthing) DO you know whats up?
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah, my drive flanges were flat, no holes.... so I made some and yanked em out
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    There are two types of full time hubs. One uses slugs (no bolts) and one uses a drive flange that bolts on. I think slugs go in a hub that takes internal locking hubs and the bolt-on flanges go on a hub that uses the external type locking hubs.
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ok i think i get it now. THe truck im getting the hub from is a 75k5 with 203 and it would have internal locking hubs so there is no bolts. Corecto?
  9. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    El corecto!
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Might try useing a huge magnet to juts yank her out... of course I had mine installed backwards so you may be able to just use some spip joint pliers on it
  11. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    once you get the snap rings out it "should" shoot out of the wheel hub, there is a spring on the back side of the drive flange. it may be held in there if the pervious owner goober'ed it up with bearing grease.
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Oh yeha I forgot about that, stupid Brent (jk) only send me the dust caps and the slugs themselves, and not knowing what I was doing, i stuck em in backwards and said, WHHEEEEE D60!
    Then fate took away the proverbial gun and told me to read the manual before operating. "Oh this here's the safety and this here's the slide stop"
