What tot do to keep tires from dry rotting
Discussion in 'The Garage' started by SCOOBYDANNN, Jun 12, 2003.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    in between "modifications" my truck can sit for long--(like lots of months long) and I was thinking of what to do to kep them from rotting in the Hot sun (usually 100's around here)
    any suggestions
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    1st suggestion- BECOME ORANGE!
    2nd look at Advance for some rubber protectant or armorall would work fine, just once or twice a week, keep them MOIST
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i'd like to hear some advice on this too.. i have a set of tires that are off-road only... if I get swamped with other $hit to do they can sit for long periods. Any advice on what will keep dryrot at bay?
    j
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm just guessing since I've never had tires sit long enough to dry rot. But how about take them off your rig and put them in a garage, shed, or your house? Something where they aren't exposed to the sun or extreme heat, plus they don't have to support your 5,000 pound truck /forums/images/graemlins/eek.gif Just an idea, I'm sure other people will have better suggestions. /forums/images/graemlins/pimp1.gif
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Keep em in the garage, or shade, or stand up pieces of plywood next to the tire's, to keep the sun off. Tire's are'nt cheap, scrap plywood is everywhere. /forums/images/graemlins/eek.gif
  6. dyeager535
    26,976
    Keep away from anything with silicone in it, and I believe that includes armor-all.
    Some kind of reaction with the silicone and UV, it "sucks the moisture" out of rubber or something. Covering them sounds like the best bet.
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Armoral will help them rot faster.
    Zaino makes a good treatment for tires.
    Actually the easiest is to get some tire covers from an RV shop or as mentioned lay some plywood against them.
  8. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    RVs come with "bags" to put over the tires while they are parked. You could get make some kind of bag to put over the tires while it sits.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Check out Summit for the sun covers that drag racers use. I'm not sure what the biggest size is though...
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    its a combination of ozone, UV light, and whatever else was left on the tires that cause them to crack. DO NOT USE ARMORALL. That stuff acutally breaks down rubber.
    For long term storage, put them in black construction grade plastic bags, and some desica/silica (moisture asorbing) packets. Then zip tie them. This will keep the air/additional moisture out. You may also want to wash and then air dry the tires to make sure there are no petrol stuck on them.
  11. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    take em off, use a tarp or an old towel to cover the tire... any kind of rubber protectant from the auto parts store would work....either way, keep the sun off them as best as possible and you'll be ok
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    yeah, idk what i was thinking, armor all protects LEATHER and vinyl sorry. . . hehe. . .but they do seel rubber protectant.
  13. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    armorall does NOT protect leather, and is not intended for leather. Do not use them on your upholstry!
  14. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I've been cleaning cars for my living for 2 years, and I can say that Armor-all is the worst thing you can put on your car. Exactly like they say, it sucks out the moisture. I see the same cars come in, they request it, and we put it on...but each time, it requires more and more to get a shine to where it doesn't shine anymore. If you're going to use something, use Black Magic as it has a different base or Leather cream. These protect better than anything else I've personally seen or used. But I second taking the wheels off and putting them somewhere in the shade or even in the A/C. Leaving them on the car can hurt the sidewall if you let it sit in the same spot for long periods of time.
  15. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    one oldschool trick is to spray them periodically with WD40. and obviously getting the weight off them is beneficial for flatspotting..
  16. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I store mine in my closet in my apartment. I would love to see the look on the landlords face if he ever opens that closet!! 4 big ole mud tires...still caked with mud!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
