what tranny are you runnin
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coreyd, Dec 19, 2005.
  1. coreyd
    coreyd Registered Member
    Mar 24, 2004
    76
    San Mateo, CA... from South Dakota
    I have a 90 burb, 3/4 ton, 456 gears 37" tires with the 350 400 241 combo what are the rest runnin. I ask because i am thinking about changing it, at freeway speed 75 or so i am at 3100.
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    same combo in my 89, except 33s and 4.10 gears. 3000 at around 70mph.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I currently have 700r4 with 3.08 and 31s and turn about 1800 at 75:D .
    I am going to 4.10s and 37s calculated I should be about 2700 in 3rd locked at 70. And as soon as I have the money 5.13s are goin in the 60/14FF.:D
    Ira
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    So are you thinking of overdrive?
    Bascly you have 3 choices As far as transmissions go
    1.4L60/700r4. Auto trans
    Pros: Will bolt right in with drive shaft and crossmember? mods.
    OD tranny better MPG, Low 1st gear,Fairly Easy swap.
    Cons: Weak tranny. Espically in a 3/4 ton. Need to get a built one for your big tires and 3/4 tom running gear. Also need a very good tranny cooler.
    2. Go manual with a NV 4500
    Pros: Overdrive and a little stronger than a 4l60
    Cons: It is the weakest of the manual trannys. Will require more modification. Clutch, cross member, driveline, ECT could get expensive unless you have a donor vehicle handy.
    3 4l80E Auto trans
    Pros: Great strong tranny. Will bolt in, (May require slight driveline mods.)
    Cons: Need a $800 computer to run it.
    Or you can get some kind of an aftermarket overdrive unit.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Any tranny you swap in other then an NV4500 manual or a 4L80E auto is a downgrade from a TH400. With 37's on a Burb I wouldn't even consider downgrading to a 700R4. It is a waste of good money.
    I have had a number of 700R4s in my K5 and I am never going to pay for one again. If I had the money I would swap in a 4L80E. I don't have the money so I have a Th400 sitting in my garage waiting to be swapped in.
    A 4L80E may have an $800 computer that you need but with a good 4L80E and the $800 computer you will end up spending less in the long run over a 700R4.
    Harley
  6. coreyd
    Mar 24, 2004
    76
    I have been really thinking about the 4l80e, I guess i will start my search for one now, thanks.
  7. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    find a 91 with a 4l80 in it and swap out the wire harness and plug in the stuff and be done with the swap. 4l80-e is basicly the same tranny as 400 buut over drive. i think its the same 1-2-3 gear ratios. i love my 4l80-e .
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    easier to get larger tires..... :Wink1:
    Grant
  9. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got a 1ton k5 that will be running 40's soon wth 700r4 and im debating bout either building up a 700r4 or 4L80e when my current tranny goes....im not sure what ill end up doing
  11. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Love my 4L80E. Can't even hear the motor over the road noise at 70. Go for it if you can afford it, it's the best option, IMO.
