What tranny could it be?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burbBoy, Jun 22, 2003.
  1. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    I found a 80's chevy 1/2 ton 4x4 6.2 and what looks like a 208 t-case but the tranny is what puzzles me. Its a 4 speed with reverse up to the left and the shifter is set back further from the dash unlike the sm465 im used to seeing. The tires are flat and it's in weeds taller then i am so i couldnt crawl under it to see what the tranny looks like. I would guess is some sort of side loader but i didnt think they were ever offered in a 4x4. Any ideas?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
  3. dyeager535
    26,978
    Don't know as they were offered with the diesels, but I've seen a factory 208 equipped truck with the "side loader" 4 speed before.
    Shifter "console" part of the 208 shifter? Same piece of plastic? IIRC thats how the one I saw was set up.
    Not too common, I believe after the early 80's the 465 was the only 4spd manual available.
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    6.2 Diesel?? They never offered or made any diesels with manuals from the factory in that era. So if it's a 6.2 diesel with a manual tranny, it's a custom job...
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 6.2 was not available before 82 so if it's an 80 it's not stock and any tranny could be behind it.
    /forums/images/graemlins/thumb.gif
  6. Kennedy
    Kennedy Registered Member
    Mar 1, 2000
    90
    Los Angeles, CA
    It's an NP A833 4-speed that was commonly ised in early GM diesel trucks and in just about every Mopar from the '60s and '70s.
