What Tranny is this
Discussion in 'The Garage' started by ks2krpt, Mar 9, 2003.
  1. ks2krpt
    ks2krpt Registered Member
    Mar 6, 2003
    47
    Adirondack Mts, NY
    I guy is selling a Tranny and married T case from what he claims was a 1991 Chev 1500 4x4. The Tranny is a 5 speed OD
    but it has no id plate. It is NOT a NV-4500. It looks more like a ford M5R2 4WD. The Tranny case is almost oval, made from aluminum and has ribs on the outside. The T case is left hand output to the front diff. I looked at it and can verify, there are no ID plates. Any idea what this is ?
    He claims he rolled the truck and thus pulled the drive train. If its GM, does it have the same bell house as a CH 465? Thanks for any help. He only wants $250 and its really clean.
    Paul
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If it really came out of a 91 GM wouldn't it have to be a NV4500?
    Maybe someone will have a better Idea than me /forums/images/graemlins/confused.gif If you could put up a pic of it that would help.
    Eric
  3. bigjbear
    Feb 18, 2000
    13,966
    447
    Marietta GA
    It might be a Getrag 5 spd. They were also used in Fords, but I don't know the desig #.
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    If the bellhousing is made on the trans it's prob the Muncie/Gertrag 5spd.Pretty good trannies,but,first gear isn't low anough.4 to 1 first gear. /forums/images/graemlins/thumb.gif There was also one called MT 8,possible it's that if it has seperate bellhousing.Haven't seen one so can't say for sure. /forums/images/graemlins/thumb.gif
  5. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    I Think you hit the right tranny. The BH is part of the tranny. Can you give a model number so I can look up specs ? What T case would GM have married to it.
    Thanks for the help. I agree, the low gear is now low enough.
    Paul
  6. bigjbear
    Feb 18, 2000
    13,966
    447
    Marietta GA
