what trans/case in a 73 K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater_k20, Dec 26, 2003.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i came across a guy with a complete drivetrain out of a 73 K5 for sale real cheap. he has a Dana 44 front, a 12 bolt rear. both have 4.10 gears, and the rear has a posi. he's not real sure which trans and case he has though. the trans is a 3 speed manual, and the case is a part time unit. i assume the case is a 205, but what about the trans? assuming it is a 205, what other trans could i bolt to this case if the 3 speed isnt worth a crap?
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    It's like an SM 420 or 435, I think one of those is a 3spd. I would swap it out for an SM 465 4spd and yeah I would bet that the t-case is a 205. I find the 4.10's in the 1/2ton running gear interesting. /forums/images/graemlins/thinking.gif
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Year:: 1973 Production Total: 44,841
    Base Price: 3,200 Weight: 3,912
    Wheel Base: 106.5 in. Fuel Tank Capacity: 20-gallon/31-gallon
    Length: 184.5 in. Height: 71.5 in.
    Std. Engine, (net HP):
    OHV Six-cylinder 250 cid. (100) @ 3600 rpm
    Opt. Engine, (net HP):
    OHV Six-cylinder 292 cid. (120) @ 3600 rpm
    OHV Eight-cylinder 307 cid. (115) @ 3600 rpm
    OHV Eight-cylinder 350 cid. (155) @ 4000 rpm
    Rear Axle:
    GM Corporate 12-bolt (8.7/8-in. 1.31 Axle Dia. 30 Spline)
    Front Axle:
    Dana 44 (8.5-in. 1.31 Axle Dia. 30 Spline)
    Transmission (M):
    SM318/SM326/SM330/T-89A/T-150 3 spd. (2.47-3.50:1 First Gear)
    SM465 4 spd. (6.55:1 First Gear)
    Transmission (A):
    TH350 (2.52:1 First Gear)
    Transfer Case (M):
    NP205 (1.96:1 Low Range)
    Dana 20 (2.03:1 Low Range)
    Transfer Case (A):
    NP203 (2.01:1 Low Range)
    According to this from the spec page the 73 came with at least 5 3-speed trannys and most likely it would be a Dana 20 t-case.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah those 3-speed trannies are a clusterfuc that's for sure. I think Randy (R72K5) has verified in the past that the Blazers got the SM330's. My vote would be that it is a np205. The 3-speeds are OK, though, I wouldn't take it out unless it's having major problems. Still better than an auto! (see below /forums/images/graemlins/rotfl.gif)
  5. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Just FYI, the sm420 quit going in trucks (I think it even stopped production) in 1967. 68 was the first year for the 465. I don't know of a sm435, but there was a np435, which is a good tranny from what I've heard.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    those are four speeds, both... 420, 465, 435, 435cr, etc
    the thre speed were the sm330, those are the 4x4 version 4 speed, the 326 and 318 were the 2wd three speeds
    dana 20 was done after 73
    dana 20 was in 67-72 years, although i dont thnk all six years, ou mainly saw dana 20 in the jeeps and such, but GM decided to use tem for a few years also, heh
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes, very correct., 420 were from 47-67, they are the old school
    465 from 68-88
    and arent three speed anyways so dont apply here
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The CK5 specs that Corey posted above are correct, the Dana 20 was still used behind 3 speed manuals in '73 (in Blazer/Jimmy only, Dana 20 was never used in GM trucks). I would bet that is what that Blazer has.
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I dont think that is odd at all. My brother has a 79, with the original sales brochure, and it lists 4.10's as standard for that year. He luckily got the option of having 3.08's. /forums/images/graemlins/rotfl.gif Those got changed out real quick after he found out they were so high. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    -Harrison
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]I don't know a lot about manuals especially outside of an sm465 or nv4500. I stick with automatics. /forums/images/graemlins/wink.gif NP instead of SM 435... oops, picky aren't we. /forums/images/graemlins/smile.gifj/k /forums/images/graemlins/rotfl.gif
  11. Grim-Reaper
    7,385
    Atlanta
    Well if it's truely a 3 speed then it would have to be the 330/20 set up. I just didn't know they ran that in 73 at all. My bud had a 71 that had that set up factory and he ditched it for a 700R4 with vett servos and a 208.
    Now a LOT of people call 465's 3 speeds with granny. Maybe what it actually has.
  12. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Pun intended? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Oh I hate when people do that, especially my Dad. I called the parts store needing something once and I told them I had a sm465 4-speed and he said "NO, it's a TOP LOADER 3-SPEED!!!" /forums/images/graemlins/rotfl.gif Refuses to believe me that they're one and the same.
