what trans mounts for doubler
Discussion in 'The Garage' started by ShitownK5er, Sep 9, 2006.
  1. ShitownK5er
    ShitownK5er 1/2 ton status
    Nov 7, 2000
    121
    Shillington Pa
    im makeing a crossmember for my doubler and i was wondering if anyone had any suggestions on what type of trans mounts to use. I was going to try and use the stock ones but i wasnt sure if there was a better one.
  2. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    I had good luck with a second set of the factory ones.
    I actually used a stock crossmember but had to space it down some... the middle one has the wedge shims. Anyway, the factory mounts worked for me, especially since I had a factory crossmember and the ORD Doubler was drilled for them.
    http://www.slosh.com/dremu/first-two-crossmembers-mounted.JPG
    http://www.slosh.com/dremu/xmembers-mounted-1.JPG
    -- A
