What transfer case do I have?
Discussion in 'The Garage' started by Eric M., Apr 18, 2005.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    It's a 74 GM 3/4 ton. The shifter has 4 hi, 4 lo, Neutral, 4 hi loc, 4 lo loc.
    Is this a 203 or a 208? What is the diffeence between the two?
    Thanks,
    Eric M.
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    It sounds like a 203....
    Does it have a fixed yoke rear out-put???
    The 208 is ALL aluminum...
    the 203 is cast iron...except for the rear output..it is aluminum.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    203
    208 wasnt until 80
    80 is aluminum and part time
    203 is a whole different thing
    203 is full time and iron case
    you have no 2wd position, you are always in 4x4 in the 74
    although both happen to be chain driven
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    208 started in '81, the only t-case used by GM in '80 was a 205 (regardless of truck configuration).
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    You will have a NP203 with that shift pattern. The NP208 was not offered until 1981 (1980 the only Tcase available was a slip yoke NP205 no matter what tranny you had).
    The NP203 is a cast iron case, chain driven, 1.96:1 low range available behind auto trannies from 73-79 and SM465's in 1974 only.
    NP205 cast iron case, gear driven, 1.96:1 low range Available behind auto's and manual tranny's 1970?-1990 (1981-1990 only in 1 tons)
    NP208 aluminum case, chain driven, 2.6 or 2.7?:1 low range available from 1981-1990 in 1/2 and 3/4 tons.
    I may be slightly off on the ending years available though.
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks. 203 it is.
    So, a 208 is a part time unit?
    Eric M.
  7. kennyw
    Jun 9, 2002
    13,224
    94
    Yes
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    205 is part time and gear to gear. best in my book other than 2.0 low range.
  9. browningejm
    browningejm Registered Member
    Mar 23, 2005
    47
    LONG ISLAND, N.Y.
    I just looked at mine (75k5 np203) it shifts.. low lock,low,neutal high,high lock
