What type of engines do we have
Discussion in 'The Garage' started by SlicksInRain, May 2, 2007.
  1. SlicksInRain
    SlicksInRain 1/2 ton status
    Jan 7, 2007
    238
    Chicago, IL
    I just want to know what you would call our engines. For example LT1, LS1 that kinda stuff. Is there a link that has this info? I always thought we had LT1s but I was told that was only in Camaros and Caprices. Anyone have a model number or at least the one for my 1990?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The engines in K5's have designations, but it isn't LT1.
    LT1's have a reverse cooling system, an optispark distributor mounted on the front of the motor and a bunch of other stuff that is unique.
  3. mello_yello
    mello_yello 1/2 ton status
    Jan 16, 2006
    167
    Orange, CA
    first generation small block chevy, V8,
    or fourth generation Big Block Chevy V8
    i dont know the designation of the diesals, or the option numbers
  4. bigjimmy82
    bigjimmy82 1/2 ton status Premium Member
    Dec 9, 2005
    362
    11
    New Albany, IN
    call it SBC350
  5. SlicksInRain
    Jan 7, 2007
    238
    Chicago, IL
    I got the factory engine out and wanna know what model parts to look for performance wise. It's been rebuilt and isn't much like the original at all, so maybe it's something else now??? :confused:
  6. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    As I understand it LT1, LT4, LS1, LS2, etc are the engine's RPO (regular production option) codes. All your RPO codes should be listed on a sticker in you glovebox. Mine (a TBI 350 from a '89 K5) is an L05. You can look up RPO codes on websites like http://www.73-87.com/chevy_ids/sbrpo.htm and http://www.chuckschevytruckpages.com/rpo_codes_1973-87.html . Be carefull because the meaning of an RPO code may change from model year to model year. If the engine is not stock you can look up the casting numbers using http://www.mortec.com/ . Hope that helps.
  7. mello_yello
    Jan 16, 2006
    167
    Orange, CA
    i believe your correct on the RPO thing, casting #'s i think are more important probably too
  8. SlicksInRain
    Jan 7, 2007
    238
    Chicago, IL
    Thanks thats just what I was looking for.
  9. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    don't the newer k5s, 89-91, have reverse cooling systems? When I replaced the water pump on my 89 I was looking for a good aftermarket one (with more flow) there was only like one or two companies that offered one for me.
    But if I searched for a 85 k-5 with 350, there were a ton of companies that offered a high volume water pump :dunno:
  10. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    As far as I know, the first time GM used reverse flow cooling was in the '92 LT1 Corvette.
    -Wes
  11. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    The newer trucks need a reverse flow waterpump, but that is becuase the serpentine systems those trucks have make the waterpump turn backwards. The fluid still flows in the same direction as the older trucks though
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    LT1's were the "hot" small blocks in the early 70's . Its just an RPO number , and they DO get recycled by GM .
