What type of Rear shaft are you running?
Discussion in 'The Garage' started by BigCountryx, Jun 13, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Need input on what other K5ers with 6" to 8" lifts are running for rear driveline. Inparticular those who have or had tailshafts like an NP241. I will likely go with a SYE new shaft, but if any one is running something different and having success, I'd like to hear it. The setup I'm looking at is approaching 900 bucks, ouch! But if I have to I will.
  2. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    im running 4inch springs and 5inch blocks in the rear, transfer case shimed down with spacers 208 transfercase and i just got a longbox driveline and had it shortened after i rotated my pinion angle be rewelding perches, no vibes or bind.
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have 4" blocks in rear and mine vibrated like crazy. I bought a shaft w/ CV joint. No vibration at all.
  4. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    5 inch blocks!!! :eek: :eek: :eek1: ..wow..
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If you run a SYE you can probably run a standard shaft instead of a CV driveshaft. You might even be able to use a stock one out of a late 70s K5 with a TH350/NP203.
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    hey now its just temporary im am taking the lift off this weekend to put it back onto my shortbox and it has 8 inch rear springs, so i will only have to use a 2inch block
  7. BIG*RED
    Mar 14, 2003
    1,094
    its all good..i just read that, and couldn't resist poking a liitle fun at you! ;)
