What vehicles use 5 on 4.75 bolt circle?
Discussion in 'The Garage' started by josh86k10, Jun 4, 2006.
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I recently acquired a small utility trailer to pull with my Cherokee (for some reason my truck is no longer very highway friendly :dunno:). The only problem is that one side has a 205-70-15 and the other side has a 195-60-14. So I head to TSC and buy 2 175-80-13 tires (already on wheels) on the assumption that 5 on 4.5 is standard on basically all trailers. Maybe, maybe not, but this one is 5 on 4.75 :doah:.
    So my question:
    What vehicles use a 5 on 4.75" bolt circle and would have wheels with a big enough hole for a trailer hub to stick through? 2wd Chevy fullsize trucks? S10's? Having different sized wheels drives me nuts (even though it pulls fine). Plus one of the tires doesn't hold air anyway. Once I know what to look for I'm heading to the junkyard. Maybe I'll even find some with some decent rubber already on them.
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    s10/s15, rwd chevy cars (except wagons) including firebird/camaro/corvette.
    stay away from the real new stuff and 4x4 s10s, they have weird offsets that will probably put the tire into the side of the trailer.
    fullsize trucks are 5x5, as are astro vans, and fullsize wagons
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    13"???
    If you are looking for 13" rims with 4-3/4" bolt circle, Chevy Corvair rimsl fit that description...IF you can find any Corvairs in your local boneyard!--we sold a lot of them at the boneyard I worked at..guys used them on the front,to get that "drag car" raked look on older Camaro's and Chevelles...:crazy:
