What vortec spark plugs?
Discussion in 'The Garage' started by neverendingproject, Aug 26, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    What spark plugs do I use for my vortec heads (96-99 SBC)? I know they are picky and they have to be longer than normal SBC plugs, but what gap, brand, and heat range should I look for? After two weeks of cussing, I figured out my ignition problems were the plugs, so im off for new ones.
    I used autolite (all the parts store sells) and I dont want platinum plugs because I've heard the have a general heat range and not the best thing for the vortec heads.
    Thanks guys.:o
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    your gap is going to depend on your ignition system, not the head it depends on how much voltage your coil is producing.
  3. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Champion # is RS12YC, gap @ 0.045. Stock or Summit coil.
  4. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I have a MSD distributor and coil, but no box, do I need to swap back to a stock coil?
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    no a aftermarket coil will produce a larger voltage allowing a little bit larger gap to be run, your best bet is to find a plug that works then play around with the gap and see what makes it run the best
  6. jms
    Jan 24, 2001
    1,683
    I was just pointing out that I've used this plug/gap combo with both the stock '85 HEI setup as well as with an aftermarket (Summit) HEI; engine is a carbureted 350 w/ Vortec heads. I've also used hotter RS14YC plugs to address lousy #7 and #8 plugs; all plugs look to be a little on the white side.
  7. dyeager535
    26,980
    Just go buythe AC Delco plugs for a Vortec motor and run them.
    "Normal" HEI applications will jump anything .035-.060" gap, and GM did just that with the exact same ignition setups, depending on year and engine make.
    Anyways, the Delco plugs are great plugs (apparently NGK's) and not that expensive if you can find someplace that sells them.
