what was that trick for the stuck auto hub on a D44?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Jul 13, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i did a search but i could not find it....
    please help. the drivers side will not come out. it is not enguaged. it feels like it is caught on splines or something....
    it moves back and forth about .25 inches behind the groove for the snap ring but will not pass the grove.
    grant
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    UMM did ya take out both snap rings ? BFH time !!! j/k
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    he he, i wish it was that simple... i tried a medium hammer, i dont want to damage the shafts at all so i have to be a bit carefull. any other ideas?
    grant /forums/images/icons/confused.gif
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    its automatic hub. has nothing to screw into... i could drill and use jmy tap and die set..... /forums/images/icons/confused.gif
    grant
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You could try a short piece of angle iron with holes drilled for two of the torx screws that hold the cap on to go through. Put a socket that fits into the center of the hub against the stubshaft and tighten down the screws to pull out the hub body. Don't ever put it back in......throw it away and get some manual hubs.
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    automatic hubs dont have any holes for screws....
    but i ended up getting it off... kind of in a brutal way but the shafts are not dammaged. i took my favorite tool to the hub case. SAWSALL!!! cut just behind the hub sprag and remover the two together. i need to replace the hubs anyway for 8 lug conversion.
    i thank all of you for your ideas. most of them would have worked if i had manual hubs.
    grant
  8. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    Hmmm....maybe 1/2 ton hubs are different. My D60 autos had five torx screws that held the cap onto the body.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, they are flat as can be. but i fixed the problem. got the shafts out. thats all i needed. now i can part the rest of the dam* thing out.
    grant
