What was the first year for the Chevy 1 Ton 4x4 IFS?
Discussion in 'The Garage' started by DPI, Jan 9, 2005.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    My nephew is looking at a 1988 K3500. I could have sworn the first year for the IFS was 1992, but this shows to be an 1988. However, the car fax he ran shows the first event as 1993, but doesn't show the mileage. It has no history, on car fax anyway, between 1988 and 1992. Does this sound fishy or am I just loosing my mind.
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    axle info
    if its a std cab, ext cab 88-up. if its a crew cab 92-up. car fax is only good if the damage was reported to the insurance company , so thay can list it . i have seen lots of good clean carfax info , but car or truck has been trashed before. :cool1:
  3. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Didn't they sell both a K3500 AND a V3500? I think the K model had the IFS from 88 on, but the V3500 had the old sheet metal and solid axles? I might be wrong, but I'd swear I read a post on this a couple years ago.
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    from what I understand, in 87 the 4x4s became the V series, and the 2wds the R series. In 88, the new sheetmetal ifs 4x4's became the K series, and the new body style 2wds were C series.
    besides Blazers and Burbs, the only V series truck were the crew cab pickups and the chassis/cab models (which could be reg cab as well). but all single cab 1 ton 4x4 pickups were IFS.
    correct:confused:
  5. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I think you got it right Atho.
  6. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Atho's got it right.
    1988 is this first year GM went with the IFS front on there 4x4s which were designated as K series trucks.
    From 1988-1991 GM still offered old square body style SFA 4x4 Blazers (all), Suburbans (all), Crew Cabs (all), Cab&Chassis' and finally Regular Cab Duallies all of which were designated as V series trucks.
    Edit: I have a 1988 Chevrolet V30 (SFA 4x4) regular cab dually.
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Might be wrong, but here goes-
    88 was the introduction of the newer body style, but was only applicable to the 1/2 ton and the 3/4 ton Regular and ext cab styles. The one ton remained the same until a later date, (I believe 1991 was the last year of the older body style). There was some terrible naming conventions however- The pickups were named, the Chevy "C/K Pickups" (C=2wd, K=4wd). Crew cabs were not avaliable on anything less than a 1ton.
    There were some other things I havent been clear on- When was the production dates for the 3500 HD units? (they come standard with 19.5" wheels, and I believe are 2wd only). THey do however, use a solid front dummy axle.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Add reg cab & ext cab 1-tons to that too. They also started making the new body style dually while the SAS was still in production. I can't nail it any closer than 88-91 though. These trucks usually turn up with that odd-ball Dana 70-3U in them.
    Lots of C20 crewcabs were produced. '88 was the latest R-series I have encountered. They have a 1-ton frame & axle, but the 3/4-ton brakes.
    '91 is the first year. They're on Dremu's brochure page. I believe '01 or '02 is the last year. They're based on the heavy P30 chassis used in the bigger step-vans and A-class motorhomes.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3500HDs come in 4wd also. If you've ever seen a 4wd tow truck they're kinda common.
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A guy in our club has an 1988 1-ton dually extended cab with the new body style and IFS. It has a TBI 454 and th400 trans.
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The 3500H.D.'s did not come 4WD from GM - They were aftermarket conversions.
    Tom
  12. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    3500HD 4x4's were not factory produced. They were 3500HD 4x2's that were sent to aftermarket upfitters prior to delivery from the dealer. I know because I was working at a large GM dealer throughout the 90's. (I remeber brand new '91 Blazers sitting on the lot) You can check my 3500HD theory by looking at the VIN. The 5th digit on all the 90's era 3500HD's is a C......2WD.
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the 3500HD 4x4 conversions use 10 lug dana 70 front axles...:pimp:
