What Welder do you like
Discussion in 'The Garage' started by Taz, Feb 15, 2003.
  1. Taz
    Taz Registered Member
    Dec 31, 2000
    77
    SE Wisconsin
    It is my turn to use the tax return on anything I want. I want to buy a wire welder, I am looking at two models. The Millermatic 210 (60% duty cycle) and the Licoln 200 (60% duty cycle). I will be using this for body work and frame work. Which brand name do you like and why? the price is the same ($1150) the only difference I see is the miller has 10 more amps.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have used all types of welders (Lincoln, Miller, Hobart, T-Dyne) but I LOVE Lincoln equipment...I say go with the Lincoln...I have a Lincoln SP-135P setup and LOVE it...perfect for body work, which is what I bought it for mainly...
    Chris
  3. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    I have always had good luck with miller welders. that's what I use all day at work and have almost zero problems with them (2 syncrowave 350 tig welders and a millermatic vintage mig welder ( 310 amps ) ). as for the lincolns I've worked with.... y dad has a lincoln weld n power and that thing has done nothing but work work work and more work. it has never let him down. we have a 300 lincoln tig welder at woprk and have had nothing but problems with it since it was bought new. I have also never had any luck with the lincoln mig welders either. both are top quality industirial strength machines and both can be made to do the job and do it very well. I just have a preference for miller stuff.
    -Scott
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Either one is a good choice, we have a lincoln generator type welder and it is as old as the hils and has never broken evr. Same goes for our Lincoln mig and diesel generator. Our Miller gas powered welder is also a good unit. either way youll have a good machine capable of handleing most anything an offroader will throw at it.
  5. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I've got the Lincoln 175+ and it's great. Does really well with the thin stuff and still has enough power to weld 1/4inch. It's only 20% duty cycle and I've never had a problem with it.
    Mike
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    do they still have the spool gun promo on the 210?
    I went 250 as everyone always says buy the biggest you can possibly afford
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I stick with Millers. I have used both and have a Miller at home.
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Either machine will do you good. If I had a choice I would give the nod to the Lincoln, but I've always had good experiences using Lincoln. They seem to start hotter than the Miller...
    I've never had major problems with either brand though.
    Rene
  9. Taz
    Dec 31, 2000
    77
    SE Wisconsin
    you can get the spool gun with either machine, but it is an extra $300. I dont think I will weld Alumimun very muh so I probably wont be buying it.
    thank you for all the info
    Romie
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I can vouch for the Lincoln starting hotter. I own a new Lincoln 200....Use Miller Vintages and 250's at work. I like the Lincoln waaaaay better. Arc starts alot smoother. Much smoother arc. The Millers are nice but the arc is a bit "rougher" and doesn't seem as stable. You'd be fine with either machine though. /forums/images/graemlins/thumb.gif
    MJ- Miller isn't doing the spool gun promo anylonger....I missed it by a month or so when I got my Lincoln. /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
  11. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    Like was said, you'll be happy with either machine. What I look at more than the machine is the dealer and his services. But above all else, get the 98/2 argon tank so you have the possiblity of welding aluminum later if desired. You don't need a spool gun for aluminum. the 98/2 is a better shielding gas for steel anyways. See which dealer will throw in an electronic/automatic helmet /forums/images/graemlins/wink.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    oh to bad, it was sooo tempting when I was standing there to go with that deal.
  13. SCOTTS_4X
    Mar 22, 2002
    129
    Modesto CA
    if you are going to do any kind of aluminum welding that is going to have any stress put on it you don't want a spool gun anyways. you are going to want to tig weld it. I weld aluminum all day long at work, we use nothing but tig. we have had many companys try to do promo's of mig welders and it's nothing that you want to trust, lets put it that way. with tig welding you can actually see your puddle and control the keyhole/penetration. with mig welding it's pretty much you get what you get when you set your feed/heat. anyways, just thought I would throw that in there.
    -Scott
  14. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    That depends entirely on what you are building. There are millions of gravel boxes out there welded with MIG aluminum for example. I'd love to see someone TIG weld one /forums/images/graemlins/rotfl.gif You'd be there for a month!
    There are jobs that are more suited to TIG and there are jobs more suited to MIG. Both shine in there intended element...
    TIG is best for fine work, thin material, and extreme weld purity. MIG is best on the thicker stuff, especially if there is a lot of it. We recently had a guy at our work tested and certified for some defense work on Aluminum MIG. Minimum material thickness was 1" plate. The prep was downright anal, but the MIG got the job done.
    Rene
  15. Why me?
    Why me? Registered Member
    Jan 28, 2003
    22
    I used to be a welder repair tech and had many Lincoln and Millers apart. Ether way you will do good. Just get the BEST machine that you can afford!
