What width rims for my 33x1250x15 BFGAT's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Oct 23, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    What width rims for my 33x1250x15 BFGAT\'s?
    Im still undecided, Should I get 10" or 8" rims for my rig? I don't go in mud but I do go in snow and ice (I live in the Rockies). I do drive on the beach once a year. Will the 8" rims cause the tread to be high in the middle and cause bad handling/wear? Conversely, will 10" rims cause poor traction in snow ice situations? I drive a 1990 sub and am planning 2-4" lift. Thanks.
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Re: What width rims for my 33x1250x15 BFGAT\'s?
    I personally don't think you would notice much difference. Desert guys run 8 inchers. Maybe someone will have some personal experience. I'm goin' with 8" for my 33's.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I had 10" then 8" then 10" rims on my 33x12.50x15 BFGMTs. I noticed an increase in tread wear within a month when I went to the 8" rims. I also thought it looked funny, but that may be because I was used to the look of the 10" rims. When I went back to the 10" rims the tread evened out for me again.(after a number of miles)
    Cruisin in my '73.
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Go for the 10's. They look perfect with 33x12.50's. AND if you ever go to a wider tire, then you can use the same rims. I had 15x10's with 36x14.50's and that combo looked good too.
    '73 K5
    Chevy good...Ford bad
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Go with the 10" rims. I have 15 x 10 Eagle Alloys on my 33x12.50 BFG and they run well. I have a 15 x 8 (only spare rim I had) on the same size spare and the profile of the tire is taller. It seems to be more in the middle and the sidewalls roll more. If you have to air down the tires for floatation on the sand or for rock crawling, you'll appreciate the wider rim. My nickel.
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>I would opt for the 10" rims, they look better and like sone one said before, your tires will wear better on 10" ers.</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
  7. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    8 inchers will cause your tires to wear poorly on the road. 10's would be better because you can upgrade to wider tires for muddin' or whatever.
    [​IMG] '87 Beast
    Colorado, USA
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have the same tires as you and AE 589 15x10 wheels and they look and work great.
    90K5
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I run 10" Centerlines with those exact tires. NO issues, plussssssssssss..........if you want bigger tires later on in life, you don't have to change wheels!
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  10. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    10" here under my 33s. better when airing down for the sand dunes than my previous 8" steel wheels.
    Knife.
    knife.coloradok5.com
  11. Cornfed-90K5
    Cornfed-90K5 Registered Member
    52
    Fresno, California
    8" rims give you better bead retension for runnign low air pressures, but you may experience adverse tire wear in the middle of the tread. With 10" you shouldn't air down as low because the tire puts less pressure in the bead area, but you also won't need to because the tire will have a wider foot print.
    Cornfed-90K5
    1990 K5 Blazer
    1977 Jeep CJ5
