what will blow up my 10bolt faster?
Discussion in 'The Garage' started by cochino12, Aug 5, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    4:88 gears w/posi or 4:88 gears w/out posi. This is a daily driven rig, wheeled occasionaly but mostly mud. Oh also with 35" tires
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Most likely with the posi, but with 35's I don't think you will have a problem if your a light wheeler...DD and sometimes mud may not break it.
  4. cochino12
    Dec 23, 2003
    563
    Parker, Co
    What about a powertraxx no slip unit (I can get one cheap)
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Aftermarket full case posi or locker , or lockright in an open case are much stronger than gov locs or factory posi's . You will break a shaft occasionally if you drive hard in rocks and stuff /forums/images/graemlins/k5.gif
  6. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    govlock blew mine w/ stock gears and 31s
  7. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Said 10 bolt in air....wheels spinning with generous application of right foot to skinny peddle....return to terra firma with said right foot still buried in skinny peddle...
    I ran a auburn pro series LS in my 10B with 4.10's for allmost 5 years before she gave up the ghost at EJS this year...all i ever broke was a axle shaft...actually twisted the yokes so good i pooped out the c clip holding in the u joint cap....which in turn let said cap fly be free....had fun getting the shaft out due to the spread ears but i was amazed that a LS had enough holding power to do this...
    DW
