What will fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DumontsK5, Aug 15, 2006.
  1. DumontsK5
    DumontsK5 Registered Member
    Jul 26, 2006
    59
    williamsburg, VA
    I am looking to go from 33" to 36" i only have a 4" skyjacker lift! will the 36" fit with minor trimming or should i get a 2" body lift? and will a 15x10 rim fit?
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  3. DumontsK5
    Jul 26, 2006
    59
    williamsburg, VA
    thanks man! i found some 37" baja claws on sale for 199$ a peice so i was thinkin about gettin um but i have 10 bolts front and rear will they hold up if i just do some trailing and muddin! nothing major?
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Sure, the 10's should hold up unless your a throttle jockey... About as big as ya wanna run on em...
    you'll need to trim pretty good for sure with a 4... I'd throw a 1" body and maybe some zero rates in... that should keep your trimming to a minimum...
  5. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    I wouldn't run 37" and 10's. They will last till the first time you pull off the pavement, then you probably be walking home. Just my 0.02
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    So you need a 60 for 37's?
  7. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I ran 40's on a 10 bolt and plan on running 39.5's on the 10 bolt I have out in the carport. I have even seen 42's on a front 10 bolt hold up to some major abuse. If you run 10 bolts and run em hard, ten make sure you carry extra shafts. Not everyone has 2g to drop on a 60, run what you can afford and learn to fix it.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Guess I should have used the sarcasm smilie... :wink1:
  9. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    you are running 37's on a 44, what's the difference.
    i ran 10f and 12r with lockers and 36's beat it to chit and it lasted 2 years with little to no problems. I see 37's lasting no prob. Just dont be stupid.
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I just said that for their information. Everyone thinks that with a 10 bolt you can't run anything over a 35. I was just expressing that you can run larger, but carry spare parts. Now that was for a front, I couldn't tell you about a rear but I ran 35's on my 12 bolt rear and had no problems. When I went above 35 I dropped in a 14bolt.
  11. Jackedup86GMC
    Jul 27, 2006
    64
    Southeast Texas
    Well their isn't much difference between a 44 and a 10 bolt. And as has already been pointed out here by others, I also carry spare parts. Rereading my first post here I wasn't clear, but I was mainly talking about the rear.
