What will it take to run a 4L60 with my 208?
Discussion in 'The Garage' started by Lotsa_Faith, Nov 21, 2005.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    What kind of adapter will I need to run this transmission? Also, I'm carbureted with a TH400 right now, I won't need anything electronic will I?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Is it a 4l60 or a 4l60E. If it is a 4l60E then you will need the computer to tell the Tranny when to shift. Other than that it is identical to a 700r4. If your 208 is behind your 400 you will need to change the T-case input gear to 27 spline.
    Ira
  3. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    Its a 4L60E. So theres no way around getting a computer to tell it when to shift? I thought I had heard about something you can buy to put on it to make it shift itself on here. Also, is there another transfer case I can get to work with the tranny like a 205 or 241?
  4. sandawgk5
    Oct 28, 2003
    6,881
    Any T-case from a 700R4 will be a direct bolt up to the 4l60/4l60E. You have to have a computer for the 4l60E to work properly. It can be a standalone computer but you still have to have one. Give the guys at Bowtie Overdrives a call they specialize in 700R4, 4l60E, 4l80E trannies.
    Ira
