what will this case fit it came out of 70 pickup with sm 465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MRBIGBLOCK, Jul 17, 2001.
  1. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    it has no adapter will this the a 350 trans it is a np205 thanks
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Count the splines on the output shaft of the transmission you want to mate it to, then count the splines on the input to the transfer case, they should match in number. Adapter's for 350 to 205 should be abundant. Did this case come out of another GM vehicle? If it came from a ford or Dodge, I think the front yoke will be on the wrong side, but I think (and if I'm wrong, someone please post!) you can make some small mods to flip it over to the correct side.
    edit: oops, forgot the sm465 part... It's more likely from a GM...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**<P ID="edit"><FONT class="small">Edited by newyorkin on 07/17/01 12:21 PM.</FONT></P>
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If you are trying to put it behide a turbo 350 you will need a 350 to 205 adapter and you will have to change the input gear on the 205. Steve Watson at Offroad design has the input gears
    I thought I was wrong once,
    but I was mistaken
