What would be easier? 205 question
Discussion in 'The Garage' started by clarkjw24, Sep 21, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've gonna swap in a sm465/np205 combo soon. This NP205 has slip yoke and flange. I've got a 350/205 fixed yoke version also. Which is easier? Change the slip and flange to fixed yokes or just swap the inputs on the cases? Should I keep the flange? Which would you do?
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    you should sell me that 60 you just snagged!! :)
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I would but I've been waiting to find a deal on a 60 for 3 years. :D
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    YOU GOT A 60???????????? And I haven't gotten a PM about it yet:mad::mad::mad::mad:
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Its on the way.
    Any help on the topic? Anyone. :crazy:
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i would guess (since ive never been into a 205), that it would be easier to swap the outputs....but ive been wrong before.
    id be all over it if it was a new style np/nvg case.
    ryan
  8. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    to swap out put just remove back half. but to do front input all from rear in needs to come out. so easy option is tail only.:wink1:
  9. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Not that I'm an expert...........
    I would swap the output shafts, woud be easier in my simple mind. Is that the 205 from me??? :D
  10. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Yeah the fixed NP205 is the one I got from you. I had 2 350/NP205s but both were slip and then I got the sm465/np205 and its a slip also. Original plan was to just put the fixed one behind my TH350. But then I had to watch BigPappaB's 454/sm465/np205 in slow crawl action in tellico.:bow: I had to have one. :rolleyes: I'm wanting the fixed yoke so I can make some square long travel shafts to complement the rear 63"s. :wink1:
  11. s_overstreet
    s_overstreet Registered Member
    Apr 4, 2005
    8
    houston, tx
    Keep the flange and replace the slip yoke. The slip yoke is easy to replace with simple tools. Just need to watch out for the bearings in the end of the shaft. Can be held in the end when reassembled with common grease. did it to mine.
