What would be the best option if I had
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NightRider, Oct 20, 2002.
  1. NightRider
    NightRider 1/2 ton status
    Aug 13, 2002
    119
    Charlotte, NC
    an ORD 4" shackle flip and wanted to get the tuff country 6" springs/shocks/arm in the front. what should I do to get the other 2" in the rear? /forums/images/graemlins/k5.gif
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The best would be 2" rear springs. You could save some money with 2-3" blocks (depending on the sag or your rear springs), but it would not be as ideal.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    How about a longer shackle and an ORD 1" zero rate. That's what I'm planning.
    tom
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That would work if there is an after market longer shakkle.
    Does anyone know of a rear longer shackle for GM?
    If you can find one I would do that with the zero rates.
  5. NightRider
    Aug 13, 2002
    119
    Charlotte, NC
    if ne one knows of longer shackles, lemme know plz! thx for info guys. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    The zero rate would be fine, but the longer shackle is a BAD idea. With the shackle flip, you will move the rear spring eye down, causing the pinion to point up. If you run a longer shackle, it will cause the pinion to point up even more. If you do that you'll wind up with way too much pinion angle. 2" blocks would be a better option. Another option would be a long add a leaf and the zero rate.
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I know about pinion angle issues, I know how my geometry works, and I know that in compression there will be more side stress on the shakle and I can reinforce that. I was just trying to find one that is already made so I can work with it, instead of fabing it from scratch. Thanks for the info though, I am sure some people here don't realize that.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    Do what you want to, but rest assured that you will be sorry if you use the shackle flip AND longer shackles. I have 8" of lift and the shackle flip alone (non tapered 4" blocks, factory height springs) point my pinion at the perfect angle for a CV driveshaft. Ideally, my pinion would point down more.
  9. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    You can get the extended shackles from the lo-rider club.Summit sells them about $40 bucks,4" longer the stock.I've seen them from "desert steel","summit", and "bell" companies.Of course you will need to do a shackle flip to go with the extended shackles.I have'nt done this yet,trying to toy with an idea of double rear shackles! /forums/images/graemlins/laugh.gif
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have already a design for the double shackles, and I have an example on a toyota with chevy springs. That is even worse than the long shackle with the flip.
    Still I wouldn't worry much because of my driving style.
    I think all these options would be better than this jeep I saw in fourwheeler a couple of years ago with no shackle in the back, that limited his dropp to the extended length of the shock, it was no highway racer but it worked on the trails.
