What would be the optimum trans for a 454?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Apr 23, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    My 454 is matched to a TH350. The trans always seems to leak no matter what I do (have replaced the pan gasket several times). I suspect maybe a hair line crack in the case because it is so undersized for the engine. Any suggestions?
  2. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    th350 o.k. if built correctly and k case with the brace rods. but th400 was factory behind them. my friend runs th350 in his 454 bigblocks trucks. no problems.
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I have used both the sm465 & th400 bolted to the 454. Either one is great.
  4. J.R.
    J.R. Guest
    ive used th350 behind 600 plus hp big blocks with no problems. a well, and proper built 350 will do the job but like you said it may have a crack that is causing the leaks. try adding some dye to the fluid and use a black light to find where the leak is.
  5. sweetk30
    Nov 1, 2004
    25,544
    539
    the dye works . any good auto shop like napa will have it. its about 5 bucks or less. and just need a light and glasses just like the a/c system dye uses.
  6. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I love my 4L80e.
  7. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I cracked the bell housing on my th350 so i went with a th400 so far so good........ :D
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You can never go wrong with a sm465 behind a BBC.
  9. chevy_addict
    chevy_addict 1/2 ton status
    May 4, 2004
    138
    You are here, I am not
    For those of you running 454s and SM465s, do (did) you have any issues with the gear splits in the SM465, particularly when towing uphilll?
    Dave
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    my thoughs to the "T"
    a 4l80e is the ONLY auto trans in a RWD vehicle i have not blown up. i had my th350 built several times by "one of the best in the area" and i could not keep it alive with a SM350. i had a stock 4l80e behind a 96 vortec 454 with a cam, computer, intake, full exhause and head work. i beat the everlivinghell out of that truck and NEVER once had a problem with the tranny.
    oh, other two on my vote since im a manual guy is an SM465/420 OR and NV5600.
    Grant
  11. sweetk30
    Nov 1, 2004
    25,544
    539
    ya if time and money alow 4l80-e all the way.
