What would cause my Blazer to pull to the right when I push on the brakes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Jul 8, 2001.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    I thought I would ask that here before I took her in to get looked at. Anyone else ever experience this problem with their K5?
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Could be a couple of things. A seized caliper, worn shock, worn balljoint or tie rod. Go get a " free" look see at your local front end or brake shop.
    Shawnboy.
    If you are having too much fun it's probably illegal.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You might need to adjust the rears too - that will make them pull like there's no tomorrow.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  4. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I would say something having to do with brakes. Could be pads rotors ect. It is probably something in that system
    sergio
    Check out my new website. <A target="_blank" HREF=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</A>
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Mine did the same thing. Finally I replaced both front calipers (they were both seized up pretty well) and that took care of the pulling under braking. Hope this helps.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    One of the brake lines may be plugged causing the other to brake harder....
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*
  7. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    The cheapest thing would be the calipers. I replaced both of mine and it still pulls, so we knew the ball joint was bad. The upper ball joint on the right side of mine is trashed. I am going to swap in the new axles next week, or the week after next. I need to do it SOON. Most likely I'll probably end up selling my truck, because I'm getting ready to go back to school. That means part time job and no money to play!
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  8. pregate
    pregate Registered Member
    Aug 13, 2000
    83
    Fort Worth, Texas
    mine did the same but to the left.. cost me 380 i think.. brakes were just shot..
    1979 K5 Blazer
    4x4, 350 V8
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> When was the last time you checked your tire pressure ?
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
