what would cause my domelights to always stay on?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, Apr 28, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    All my dome lights and courtesy lights stay on now. I have all the bulbs removed from them. It just happened once last x mas and now its stuck on. It doesnt matter if I push the pin switches in or not. Its weird. runs my battery down constantly
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    You probably have a bad door switch.
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Yep I'd bet the door switch is shorting out on the body.... same thing happened to me, and if you have to replace them( NAPA ) I'd suggest putting a washer on them first or when you screw them on they will not tighten down all the way due to the threads stopping short and the thicknes of the sheet metal....
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Isn't there also a position on headlight/insturment pannel dimmer switch that turns on the interrior lights? Maby that is the problem
  5. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    go to the parts store and buy 2 door jamb switches. problem solved. i changed my headlight switch first and it turned out to be the door jambs coast about 2$$ $ each . goodluck.
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i wired mine up to a toggle switch on my toggle board
    NITRO
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the lights are constant power with the door switches grounding them to light up.
    I just removed the door switches entirely.
    they like to rust
  8. FireBlazer
    FireBlazer Registered Member
    Apr 27, 2002
    10
    Milpitas, CA
    I put a aftermarket dome light in and it started grounding out through the housing- therefore my dome light stayed on all the time. The only other thing besides the door switches could be a wire thats grounding out making the lights go on.
