what would i have to do to run TPI
Discussion in 'The Garage' started by George_Pimpdaddy, Mar 20, 2005.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    hi was just wondering what i would all need to do to my 89 blazer to run a tuned port injection system ive heard that one of the best ways about doing it it to buy a used gm car with it and just swap what you need, also i heard that edelbrock sells a kit. i have a fresh rebuilt 350 with the stock tbi on it and i do alot of wheeling with my truck but its also a daily driver for me
    thanks for any help
    :k5:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Try a search. There is alot of info on TPI swaps on here. I did one personally about 1.5yrs ago.
    Harley
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yep Daily Driven rock crawler here as well.. I swapped to TPI about a year ago. There a lots of posts around here about tpi if you search around you'll find a lot of information..
    Edelbrock pro flo EFI is a different setup than TPI but still MPFI.
    Chances are your engine has pre 87 heads, so you'd need an '86 tpi manifold, or if you got a 87-92 setup you'd have to have a machine shop modify the center 4 bolt holes on the manifold so it will bolt up to your heads.
    I convereted mine from MAF to speed density so dirt and vibration won't be killing my MAF when i go wheeling especially in the sand dunes.
    The difference between a stock harness and an aftermarket harness is probably the difference between spending a week or two swapping it over, and with a nice aftermarket harness, swapping to tpi in a weekend like i did.
    This thing runs awsome on any angle, has more tq, hp, and throttle response than ever before, and it gets a few more MPG. :cool1:
    I went with Street and performance for my wiring harness and custom eprom.
  4. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Have you thought about these systems yet?......http://www.firstinjections.com/
    I am looking at using one of these on my rebuild ('90 K5). I have heard some members on this forum say that a TPI system off an older Vette/Camaro will only support up to about 300 hp. I don't know if that is true or not just what some of these guys are saying. I have no first hand experience. This "first injections" system will support up to 500 hp. I have been emailing a guy at this company and he is very helpful. Send him an email with any questions you have and he will answer. I also got in contact with someone who has installed one of these systems in an older Corvette and he said it was very easy. I would be interested in hearing some CK5er's opinions on this system.
  5. dyeager535
    26,975
    I'd convert my TBI harness over to TPI, but thats me. Reference to that in a few posts I'm sure.
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    It will bolt up to an 89. Even all the sensors are the same. You just need to use the TPI wiring harness because of the 6 extra injectors. You really wont notice any difference going from a stock motor with TBI to a stock motor with TPI.
