What would the stock power train be in a 81 1/2 Ton 4WD pick up ????
Discussion in 'The Garage' started by Z3PR, Mar 30, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  2. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    could be a 350 or 400 trans and probley a 205 transfer unless it full time the it was a 203 /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    400 trans? I am 99.9999% certain it would not be a 400. I have never heard of a 400 trans in a half ton stock.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    This truck has factory lock outs up front, so I don't belive it's fulltime.
  5. ed1507
    Jan 25, 2003
    70
    indiana
    well then its a 350 trans and a 205 case /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Would a 81 have round headlights ??? This truck does. Owner said it's a 81, but I think it might be alittle older then that.
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    If it's an '81, it would be a TH350 or SM465 and NP208. An '80 would have had a TH350 or SM465 and a NP205. From what I gather, 1979 was the last year of the NP203, 1980 was the 205 in everything, and 1981 was the first year of the 208 for 1/2 and 3/4 tons and still the 205 in 1-tons.
  9. mountainexplorer
    Nov 14, 2001
    4,903
    The one in the picture looks older than an '81. '81 was the 1st year of the slanted nose and square headlights (except ofr the factory option recatangular headlights in some trucks in '80 models). But anyway, looks like an '80 or older truck by the pic. '80 still had the vertical side marker lenses, '81 had horizontal marker lenses.
    Shifter handle in the cab should identify the t-case w/out having to crawl under. Round handle indicates a 205, handle with flat sides indicated a 203 and a round handle that angles foreward with a console around it attached to the floor that lists the t-case positions is a 208.
    If it's an automatic, I'm sure its a TH350. Most likely the whole truck will be as follows:
    350 motor, TH350, NP203 (or 205), 12 bolt rear, and Dana 44 or 10 bolt front.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, that's definitely NOT an '81. Thats an '80 or older truck.
    It will have a 350 or 465 and either the 203 or 205 t-case. Rearend will be the 12 bolt and front axle can be either the D44 or 10 bolt.
  11. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Assuming the body has never been molested, the truck in the picture is a 78 - 80 (old body style + bed has a door for gas filler).
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    And...... /forums/images/graemlins/wink.gif
    Also, the paint scheme/trim falls into the '73-'80 era trucks. /forums/images/graemlins/thumb.gif
