What would this bore and stroke equal out to?
Discussion in 'The Garage' started by y5mgisi, Oct 1, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    it seams to be 4"bore and 3.525 stroke. So what should that work out to be? i know its a small block chevy and by the casting numbers its iether a 302, 327, or 350. according to mortech. so what do you think.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    offset ground crank? maybe a custom stroker?
    comes out to 355ci.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    probly a bored 350 then because the pistons say .020 on them
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    350 has a 3.48" stroke and 4" bore so it is a stroked something maybe a 327 that has been punched .020 over.
    Ira
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Where did you come up with the 3.525 stroke number? If that is indeed the stroke and it is a 4" bore with an .020" overbore then that comes out to a 358ci.
  6. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    actually i just got one of the pistons all the way down in the cylinder and measured the distence from the top of the piston to the deck. so mabey not exactly 3.525
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    factor in the general 9.030" deck height (leaving the piston .030" below the deck at TDC) and an aftermarket piston, $100 says you've just got a regular 350 with a 3.48" stroke, and a piston that's .045" in the hole.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Put the piston at the bottom and measure, then move it to the top and measure. The difference is the stroke.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If it is a 3.525" stroke I'm thinking it's a 360ci Circle Track Rule engine.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    judging by his measurement method, i'm betting its just a run of the mill 350. if it is infact a 3.525" stroke and a zero deck, i bet you're dead nut s.
  11. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ya im also thinking/ hoping its just a plain old 350.
