what would you all use...lift degree ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Mar 7, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I need to shim my rear like 6 more degrees to have the perfect driveline angle. Right now I have 4 degree shims. I have read that someone took blocks and had them cut to the desired angle. Could I stack shims? I think to have the spring perches welded would cost too much money. I think the small amount of vibration is the reason why my t-case started leaking out the rear seal.
    baja surf nazi -...A late storm NEVER comes...
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Dont stack shims!!!!! They will walk out from under each other. Have you considered doing a shackle flip and throwing the blocks away? That would help your pinion angle alot. 10 degrees of shim sounds like an awful lot I have a 6" lift any only had 3 degree shims in it. You could also ask a machine shop to make you some shims cut to your specs.
    I thought I was wrong once,
    but I was mistaken
  3. bigblue
    Dec 6, 2000
    658
    southern california
    No, I have 6 inch rear springs. I was referring to cutting a block down to act as a shim. i will ask a machine shop when i get a chance. yeah, it is weird i still am getting some vibration ( though not much ).
  4. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    Before spending the money, drop you transfer case down one inch and see if it goes away. If so then spend the money, you might find out it is something else causing it.
    but I was mistaken
  5. bigblue
    Dec 6, 2000
    658
    southern california
    Already did that. dropped it one inch. I mean it is barely noticeable but still there. maybe a 6 degree shim would do...
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    The reason I believe he needs that much angle is that he is trying to rotate the pinion back up for his new c/v shaft and not down for a regular shaft. You are right about the shackle flip and 2" to 3" springs would probably help get him close enough to just use a small degree shim if any with the c/v shaft. Just my $.02
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
