What would you do? 205or241
Discussion in 'The Garage' started by blueblaze, Jul 29, 2004.
  1. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    Would you run a 700R4/NP241 or Sm465/NP205?
    /forums/images/graemlins/deal.gif
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Depends on a lot of factors but I'd have to say the weakest component in them choices is the 700R4. Some will say that the NP241 isn't the strongest and it probably isn't. How do you drive? How much does your rig weigh?
    I'm going to run the 241. I fully expect to be below 5000 lbs. in trail ready fashion.
    Hard question to answer. Both combinations have advantages. If it spends more time on the road I'd give the 700/241 a shot. More trail or hard trail driving maybe you should go the other route.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    700r4 generally deemed much weaker than the sm465. The 205 is preferred strengthwise over the 241 as it is all gear driven with a cast iron case, but it is much heavier.
    The 241 is a strong unit (I believe it is what is used behind the Duramax). The biggest "weakness" is it's aluminum case which can be smashed easier by trail debris and bottoming out driveshafts. It is lighter (sometimes a plus) and has a much lower low range than the 205......and skid plates can be fabbed for protection.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    What do you like wheeling better?? An auto or a stick? Thats basically what it boils down too. SOme prefer a stick while others prefer an auto..
    I, myself, would go with the 700/241.... Make sure you keep clean fluid in the 700 and run a big cooler on it! Then you should be fine!
  5. mrk5
    Apr 20, 2004
    12,341
    1,046
    Northern Colorado
    I agree with Emettology 101.
    The only thing I would add it go with low gears. If I was running a 700r4 & 35s, I would use 4.88s.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Oh, I forgot to add. I big problem that you run into with installing a 700 into a different vehcile is that the OD needs a controller for the lock up convertor. If you dont run a controller for the lock up, you will burn up 4th gear! So either get a controller for it or run a non lock up convertor. SOme quality tranny shops will have the convertor or can modify the tranny to lock up at the right time.. /forums/images/graemlins/thumb.gif
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    He's already got a 700 in it.
  8. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Right now I still have the 465/208 in the truck. I was thinking the 465/205 would be cheaper then the 700/241.
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    im going from a 700/205 to a 700/241... ill let you know what low range is like. /forums/images/graemlins/thumb.gif
