What would you get?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Mar 23, 2001.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    My birthday is in about a month,and I want to get some parts for the Blazer what should I get?Here's my list so far:
    Bolt on steering brace from ORD
    Sway bar Dis-connects from ORD
    Warn Premium hubs from 4 Wheel Parts
    Front Shackles from ORD
    My Blazer is almost a stocker besides 2.5 inch lift,33's, and 3.73 gears.I want to make a little bit more off road friendly..
    <font color=blue> Yesterday was history,tomorrow is a mystery,and today is a gift. -Taproot- </font color=blue>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I would get the hubs first.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I agree with muddin4fun get the hubs and get the steering brace. Get some recovery stuff just in case you get stuck, unless you already have that stuff.
    JD
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    If you got auto hubs I would go with the hubs too.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    I have the stock auto hubs right now. I will have to put them on top of my list.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hubs sound wise, especially when you are running automatic hubs.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    HAPPY BIRTH DAY!
    A little soon, but..
    Replace 'em when you brake 'em (the auto hiubs, if you got 'em, you will brake 'em) I'd go with the steering brace. If your frame isn't cracked yet, this part will keep it from cracking and in this case, its better to keep it from cracking in the first place. I don't think you have enuff lift to make the dis-connects usefull. The shackles (I think) are for extream duty.
    have fun, B.Y.U.
    Twiztid
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, here is the standard question again, how do you plan on using it?
    With 33s, unless you wheel hard, the steering brace can probably wait although it would be good idea before you start getting serious (much cheaper and better than fixing the frame). Sway bar disconnects will help *allot* with articulation if you spend allot of time in the rocks and such but IMHO generally won't be much use for boggin' or the dunes. The auto hubs stink and will break if you wheel hard but if you are just cruising the milder trails, they can last a long time with 33s. Front shackles are only important if you have a big lift and the springs are hitting the frame or if you are really thrashing the truck.
    If you are planning to push it at all on the harder trails, I might recommend the hubs first too. If you get out in the middle of nowhere and they break, it can cause you some grief getting back. Then maybe the brace before you get a broken frame which is also no fun. Next, the disconnects unless you live on the dunes or in the mud. With a 2.5” lift and 33s, I don’t think your gonna have any trouble with the shackles so that would be last (if at all). Instead, maybe think about lock-rites, soft-lockers or similar and upgraded axles (12 bolt rear or better) if your running 10 bolts.
    Hope that helps.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  9. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    I would get the hubs then the disconnects myself. Or and air compressona and an air wrench! Now that will help you. Will to when I get the money. I looked at my frame, 88, and honestly can't see that $90 worth of bolt on brace will do a thing. My steering box bolts right on where the cross member and the frame meet. Anyways how can three bolts really keep the frame from flexing. I think the ORD presence here wants to sell braces? Could be wrong. If it does flex and I haven't watched it yet, why not just have a piece of steel welded in. Cheaper and stronger. Just my one cent worth.
  10. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    There have been a good number of first hand accounts of how much the brace helps. I know it doesn't sound like it would, but I've seen frames busted and know how much my rig wonders when going down the road. The brace will help in both of these accounts.
  11. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Hay taterblazer, have you ever seen what happens when the frame breaks at the steering box? I went to look at a truck that was 2wd to buy it. I called the guy and he told me the steering box broke, I thought no big deal if it is just the box I could just replace it. I go to look at the truck and the box was all but on the ground along with the section of frame still bolted to it. The guy was luckey that it happened when he pulled into his driveway and not going down the road at 60 mph.
    I would say go with the hubs and the steering brace.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  12. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    to; Taterblazer'
    The ORD brace trianglulates (spelling?) the box to the frame. If you check it out from the top, the gear wants to roatate around the out-put shaft center line, this puts a push/pull (left/right) force on the frame, since the front cross member is mounted very close to that center line- it acts as a fulcrum (like a kids see saw), the brace counter acts thet force by tiing it into the fulcrum (like a wedge)- Ever think about how much force it take to turn those tires? Take the p.s. belt off and see!
    I think ORD does have a presence here, a good presents, I'am very impressed w/the what Stephan has done and the way he opperates his company.
    Sorry B.Y.U. for slpping in on your thread. How old ya gonna be? If your folks are buckin up for this present, then get them all !!!
    Twiztid
  13. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    My frame AND the crossmember cracked, and that was with 31" tires, no lift, and very mild wheeling (my father checking out farms). I say get the steering brace first.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
  14. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Stand corrected on that one!
  15. UseYourBlinker
    Jun 7, 2000
    11,117
    I'm turning 22 years old. My parent's, girlfriend,and other family is allready asking me what I want for my B-Day. It's not till May 4th,but if they have to order something online they want to make sure whatever they order get's here in time for my B-Day. I also want to get a FIRE EXTINGUISHER,and some other recovery gear. What kind of things should I have for recovery gear? Here's what I now have:
    Warn Premium Hubs
    Steering Brace (Bolt-On)
    I also need to get a Hi-Lift jack,but what size should I get?
    Also what kind of fire extinguisher should I get?
    Thanks in advance..
  16. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would get the 60 inch jack with all cast parts. As for the fire ext. I am not sure.
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    60in hi-lift all the way. i have a 48in and wish i would have got the 60in
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  18. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Fire extinguisher: Get a dry chemical with an ABC rating. Don't waste your time on a BC. You'll see numbers with the letters: <font color=blue>1A;10B,C<font color=black> or something similar - the bigger number means it's more effective on that class of fire. Class A fire is paper, wood, etc. Class B fire is flammable liquids. Class C is electrical. There is a Class D, but that's combustible metal, and I don't think there's any magnesium on our K5's. Get a decent-sized one, or 2 smaller ones; you'd be surprised how quick they run out. Get mounting brackets and mount them, so they don't turn into projectiles if you roll or get hit hard.
    ORD steering brace: When I installed mine, my steering felt better before I even got out of my driveway. Most of the vague, I'll-turn-when-I'm-ready feel my truck had, just disappeared. Plus, it's just nice to know there's some beefy steel holding your steering box in place.
    [​IMG] Semper Maintenance!
  19. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Fire Extinguisher, Fire Extinguisher, Fire Extinguisher. Um did I say Fire Extinguisher? Cant stress it enough. Seen too many really nice trucks go up in flames while wheeling or just driving down the street.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <A target="_blank" HREF=http://blueknight.coloradok5.com>http://blueknight.coloradok5.com</A>
  20. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    I agree with most others, I would do the hubs first, and definately the steering brace next, or check the frame first and see if you need the brace right now.
    Eric78K5
    K5-Because Size Matters!
