What would you use?
Discussion in 'The Garage' started by BIG*RED, Jan 24, 2006.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    So i need to hunt down a pesky little vaccume leak, So i figured I would spary something while the engine was running, and see if there is a change in rpm, when i spray certin areas.
    All I have here is
    1. Brake Clean
    2. WD40
    3. Starting fluid
    Which would you use?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    In order: 3,1,2.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    ditto, any propane torches available?
  4. BIG*RED
    Mar 14, 2003
    1,094
    No propane tourches, and I was thinking the starting fluid myself, but then got to thinking, that It might be a little too volitile (sp?)..
  5. divorced
    Jul 20, 2004
    5,115
    Nope, I've sprayed it on hot running engines all the time. If your engine is still cold it's even safer.
  6. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    2, 1, 3
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    WD is the best the other 2 have the potential to melt or otherwise mess up your rubber hoses
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I use carb cleaner.
    I dislike WD enough that I don't keep any around. There are other products that are better for any one of it's claimed uses.
  9. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    The red brakleen isnt flammable so i wouldnt use that. WD-40 and carb cleaner work good. I think starting fluid has to low of a flashpoint, not sure tho.
  10. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    3,1,2 thats my bed and ccarb clean works well too I would use carb clean over wd-40 anyday.
  11. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I think WD-40 is flammable also.
  12. BIG*RED
    Mar 14, 2003
    1,094
    Well i used both the wd40 and starting fluid...and did not find a leak, but its acting like it has a vacuume leak:thinking:
    So now i'm just scratching my head..:dunno:
