what ya think?
Discussion in 'OffRoad Design' started by luk3, Jun 10, 2002.
  1. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    would a 4 inch TC EZ ride springs on both front and rear, with the revolver shackles, 35in tires, cut fenders if needed produce a good amount of flex?
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    In order to use Revolvers, you have to use a shackle flip. The shackle flip will give you 4'' of lift by itself, so you wouldn't need the springs for the rear. If you do order Revolvers, you will have to use the ones meant for a jeep cherokee because they don't make them for fullsizes anymore. I personally don't like them because you cannot lock them in place so that they don't open up in situations where you don't want them to. That setup will offer plenty of flex if you modify shock mounts and use some seriously long shocks. Have you looked into the springer setup?
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    A 4" EZride front with a flip in the rear and stock spring should work pretty well for you, I've run around 1000 on a 20 degree ramp which is still pretty good. And simple. And doesn't have problems with axle wrap or unloading on side hills.
  4. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    whats the springer set up??
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    the Springer suspension is a suspension system made by Marv Springer.
  6. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    do you have a link to springers suspension?
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  8. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    making revolvers lock-able would not be a real engineering challenge. If you (or a buddy) can weld, you could prolly add some quick disconnects to them in 30 mins.
    J
