What year did Ford use 205s?
Discussion in 'The Garage' started by Batmanjr, Nov 10, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I'm trying to price a rebuild kit for the 205 and I have a 32 spline front output and wanted to use the Ford rebuild kit... What year did they use 205s in their trucks? Or does it make a difference? The only thing that I saw was different was the front flange seal.....
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I'd pretty much look for the '76 to '79 models as the pre-'76 had 203's and a Dana t-case (dana 21 I believe) and the 205's (married versions) were not started til '76. F250's from '73 to '77 were the remote/divorced type and '77 1/2 were the married version.
    So if you look for '76 to '79 F150 and '77 1/2 up to '79 F250 and 350, they will have 205's but some have 203's. /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had a '79 F-150 that came with a 205 behind a C6. /forums/images/graemlins/cool.gif
  4. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    I thought Chevy guys didn't work on Fords! /forums/images/graemlins/ignore.gif
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    our '78 F250 dump truck has a 205
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    And what about the GM guys who install Ford parts on GM trucks! For instance, the F250 shock towers and the F150 pitman arms! /forums/images/graemlins/thinking.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif
  7. Batmanjr
    Mar 23, 2001
    1,537
    Wess, you got a pic of that F150 pitman arm?
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    I don't have a pic of the stock arm but the aftermarket arm is no different than the one you have on your truck now. That Superlift #1104 is actually the drop arm for the '76-'79 F150's. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  9. Batmanjr
    Mar 23, 2001
    1,537
    So from what oyu just said, that means that the stock F150 arm should be alot straighter than this "Drop" Arm! Correct? I'm trying to narrow down what I need to look at to get the pitman arm raised slightly..... Gm stock 2wd arm, or the stock Ford arm...(Is that 4wd or 2wd)? /forums/images/graemlins/thinking.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Correct on the stock arm being straighter.
    I wouldn't use any GM stock arm because they have a tie-rod end already molded into one end of the pitman arm. Won't be able to use it at all.
    Just look for the '76-'79 F150 4x4 arm and see how that one goes.
    And yes, the stock and drop arm (#1104) are the 4x4 F150 arms. /forums/images/graemlins/wink.gif
  11. Batmanjr
    Mar 23, 2001
    1,537
    Will do appreciate it! /forums/images/graemlins/thumb.gif
