what year did SBC Change bellhousing pattern?
Discussion in 'The Garage' started by 69_chevy, Mar 2, 2006.
  1. 69_chevy
    69_chevy Registered Member
    Nov 3, 2005
    9
    Bedford
    What year did the standard SBC change over to a different bellhousing pattern? like 60's to when? i think its 1996 but not sure??? what is the last year a th350, or th400 or sm 465 will bolt to using standard bellhousings? Please let me know if anyone has any clue?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    ummm
    chevy has never changed the bellhousing pattern on the small block cept for maybe the real early ones like pre 1960.
    even the new genn III/genIV engines use the same pattern (minus one bolt)
  3. 69_chevy
    Nov 3, 2005
    9
    Bedford
    so even like a 2000 vortec engine is the same?
    So i can bolt a early70's sm 465 or th400 to a 2000 vortec engine?
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yep. cant put the bolt that goes in the 2 oclock postion though. can the rest. that is if its a gen III/genIV if its the old 350 vortec will bolt up no problem
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It will bolt up, but there might be a discreapancy with the flywheel though. IIRC the crank on the newer engines is in a different spot.
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Sorry. Different spot in or out, not up and down etc.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    centerline to centerline is the same. distance from back of crank to transmission i have no idea.
    guy on here has a 6.0 and 465 combo, so it cant be that hard.
