What year is a 14bFF from?
Discussion in 'The Garage' started by guido666, Nov 7, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    This should be an easy question for someone on here. I need to get some seals and parts for my truck, and I swapped in a 14bFF with 13" drums. What year/model do I tell the parts counter the axle is from to get the parts I need?
  2. guido666
    Feb 16, 2005
    788
    Longmont, CO
    This is from the axle guide, I was more wondering if this was accurate:
    GM CORPORATE 14-BOLT
    With a 10 1/2-inch-diameter ring gear, the biggest 14-bolt GM rearend looks much like a Dana 70, and is but a few thousandths of an inch shorter in ring gear diameter. This axle is commonly used with big engines and/or overly large tires. It was used under 1973-87 3/4-tons.
    So if I go in and ask for a '7x 3/4-ton axle seal, I should get what I need?
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You should get what you need with any year in that range. A safe bet is to take the seal with you. The parts guys can cross reference the numbers and look it up that way too.
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Ok, thanx for your help. I know that was kind of a lamer question for this forum, but you have to start somewhere. :crazy:
  5. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i think thay only used 1 seal for all. i have had a 76 / 78 / 96 all 14ff and same seals.
  6. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Most parts guys could. I went to Autozone with a part number I wanted to order and all he kept saying is "What vehicle is it for?" I couldn't tell him it was for a 90 Jimmy because that wasn't the original application and I honestly didn't know what it originally fit. I finally gave up and went to a "real" parts store.
  7. guido666
    Feb 16, 2005
    788
    Longmont, CO
    That's what I'm talking about! That's all they ever want to know. One guy at Advance got pissed when I insisted on looking at the u-joint book to look up one of the conversion u-joints (to go between my 1310 driveshaft and 1350 yoke). He threw the book on the counter and and walked away. That's why I asked this question, so I can tell him well the axle is out of a '79 3/4 ton, the engine is out of a '73 Chevelle, the transmission and transfer case are out of a '76 1/2 ton, ... :doah: :laugh:
  8. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
  9. guido666
    Feb 16, 2005
    788
    Longmont, CO
    AAARRRRGGGGHHHHH! I don't know what kind of tool was used to put these spindle locknuts on, but they are on SOOOO tight. I even made a special tool, like a 4-way lug wrench, but with a 1/2" socket adapter on it so I could get extra torque. Not budging. Even checked to see if they were left-hand thread (I've never taken one apart before), and they are obviously not. I looked in my Chevy service manual, it says to torque to 65ft/lb, back it off, 35ft/lb, then back off 1/4 turn. Apparently someone didn't read the manual. Any idea how to get these off? I don't own a hydraulic/pneumatic ratchet.
  10. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Oh, and thanks for the info, I bookmarked it, and did just go in with the part number. :waytogo:
  11. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    PB Buster perhaps?
    Heating works well for stuck bolts and nuts as well.
