What year is my motor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k20, Jan 14, 2002.
  1. 73k20
    73k20 Registered Member
    Jul 6, 2001
    59
    South Louisiana
    I've found plenty on v8's, Does anyone know of a website that includes v6 casting numbers? A friend has a 4.3 v6 with the casting numbers...47195.
    Who said size doesn't matter?
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Casting number is probably not going to tell you the year, though it may narrow it down a bit. Better is a small number on the deck shelf in front of or behind one of the heads. Very small, hard to see and it may not be on the newer stuff. I have several older 350 blocks that have this, though I don't know of a site or source to decode them....sorry, not much help I guess. [​IMG]
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Try going to Dorians site. (Dyeager) He has a number cruncher section on his site. I dont recall if he had 6 cyl. on there or not tho. Try sending a P/M to Twizted, he may be able to find out. ( he works at a GM dealer ) Call a machine shop. And finally call the local GM store and ask someone in parts to run the # for you.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
  5. dyeager535
    26,979
    Have you done a search on the syclone/typhoon sites? I checked one of the pages I normally use, no V6 stuff that I saw.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
